obdgpslogger takes forever to open serial port
i've got an obdpro and linuxice upgraded to 9.10. I run obdgpslogger -s /dev/ttyUSB1 which is my obdpro device and obdgpslogger reports "opening serial port, this can take a while". For the next 2-3 mins, it says that. I look at my obdpro and i can occasionally see a light flicker other than the normal power on light (i think it may be a Rx or Tx light on the PC side).
After the 3 mins, logger reports that it opened the device up correctly, the scantool failed to respond to command "00", spits out a couple sqlite create table errors and then goes silent.
I don't see it exporting dbus signals :( and nghost doesn't see them either.
any hints? are all the lights on the scantool supposed to light up?
thanks
