I installed fltk with macports and now obdgui builds properly and the program seems to run just fine now. I'll try it out soon.
I successfully ran obdgpslogger from the command line after a build from the svn (I did not try to connect to a device yet, but the program executes). However, neither the bundle on the website nor the bundle I built with cmake "make package" will run. It appears obdgui is missing when I build from the svn and it appears that the web supplied bundle crashes due to obdgui.
First, I am running Mac OS 10.4.11 on a mid-2007 (I believe) MacBook. I used Macports to install cmake and subversion.
Initially I tried running the .app from the webpage .dmg (v0.11). The application won't start, it crashes immediately. I have console.log info from that:
And obdgui.crash.log gives this:Code:Jan 8 18:59:00 john-lewis-computer crashdump[1888]: obdgui crashed Jan 8 18:59:01 john-lewis-computer crashdump[1888]: crash report written to: /Users/jlewis/Library/Logs/CrashReporter/obdgui.crash.log
I left out the "Binary Images Description:" but I can attach or send that if needed, it's quite long.Code:Host Name: john-lewis-computer Date/Time: 2010-01-08 18:58:59.313 -0500 OS Version: 10.4.11 (Build 8S2167) Report Version: 4 Command: obdgui Path: /Applications/OBD GPS Logger.app/Contents/Resources/bin/obdgui Parent: WindowServer [89] Version: () PID: 1884 Thread: 0 Exception: EXC_BAD_ACCESS (0x0001) Codes: KERN_PROTECTION_FAILURE (0x0002) at 0x00000000 Thread 0 Crashed: 0 libSystem.B.dylib 0x9010c456 _malloc_initialize + 36 1 libSystem.B.dylib 0x90002417 malloc + 29 2 obdgui 0x0000fee7 Fl_Input_Choice::InputMenuButton::~InputMenuButton [in-charge deleting]() + 10319 3 obdgui 0x00009bd3 Fl_Text_Display::buffer() + 3409 4 obdgui 0x000064bb Fl_Input_Choice::value(int) + 3267 5 obdgui 0x00005612 0x1000 + 17938 Thread 0 crashed with X86 Thread State (32-bit): eax: 0x00000000 ebx: 0x9010c443 ecx: 0x90000b18 edx: 0x00000008 edi: 0x00000000 esi: 0x00000000 ebp: 0xbffff5c8 esp: 0xbffff530 ss: 0x0000001f efl: 0x00010286 eip: 0x9010c456 cs: 0x00000017 ds: 0x0000001f es: 0x0000001f fs: 0x00000000 gs: 0x00000037
Now after building from svn with cmake and making my own .dmg (v0.12) that way I get this in console.log:
Also when initiating cmake before the "make" process I noticed these lines for items not found and seems related:Code:2010-01-08 19:03:18.161 DiskImages UI Agent[1901] Could not find image named 'background'. /Applications/OBD GPS Logger.app/Contents/MacOS/OBD GPS Logger: line 12: /Applications/OBD GPS Logger.app/Contents/Resources/bin/obdgui: No such file or directory /Applications/OBD GPS Logger.app/Contents/MacOS/OBD GPS Logger: line 12: exec: /Applications/OBD GPS Logger.app/Contents/Resources/bin/obdgui: cannot execute: No such file or directory
Are these packages I'm missing and just need to install somehow? I'm not sure what's wrong with the 0.11 build but the 0.12 build apparently can't make the obdgui and that is the cause of the problem there. Let me know where to go from here and I'll try it out!Code:-- Couldn't find fluid: required for building GUI -- Couldn't find fltk: required for building GUI
Thanks,
John
Heya,
My apologies, I was out of town so didn't see this yet. Lemme know if it's working for you! If not, I'm back and paying attention again, now
Gary (-;
OBDGPSLogger, for logging OBDII and/or GPS data
OBDSim, an OBDII/ELM327 software simulator
mp3car forums: obdgpslogger, obdsim
Well no, it doesn't seem to be working so far. When I run from the GUI, I hit Go and it greys out the buttons for a bit and then they come back to normal and nothing happens and no log file is created. Here's a screenshot of the GUI:
And just to note, the GUI does weird things spatially when resizing, and I think some buttons don't have visible labels because they're squished just above the logfile box:
I also tried running obdgpslogger from the Terminal and it runs but I see this:
The car is a Toyota Echo and I am using the ElmScan5 Bluetooth device. The device works fine even on this car with OBD Gauge over Bluetooth, I can view DTCs and see live sensor data. As far as I know the ElmScan 5 uses a real ELM327 chip.Code:john-lewis-computer:~/obdgpslogger/bin jlewis$ ./obdgpslogger -s /dev/cu.CBT-DevB-1 -d /Users/jlewis/Documents/OBDGPSlogs/echo1.db Bus error
- John L
The GUI is actually just a wrapper on the command-line application; the behaviour you're seeing is what happens if the command-line application isn't working, or is crashing. Borne out thus:Well no, it doesn't seem to be working so far. When I run from the GUI, I hit Go and it greys out the buttons for a bit and then they come back to normal and nothing happens and no log file is created. Here's a screenshot of the GUI:
Ugh. Could you by any chance show me a back trace? There's two steps to that; first, build with debug symbols, and second get the backtrace:I also tried running obdgpslogger from the Terminal and it runs but I see this:
{stuff}
Bus Error
1) Re-run cmake and enable debugging symbols; either use ccmake and change CMAKE_BUILD_TYPE to "Debug", or you can set it on the commandline cmake [building just like you did before, other than the extra parameter]:
2) Run obdgpslogger from gdb, like this:Code:cmake -DCMAKE_BUILD_TYPE=Debug .. make
The second line is typed at the gdb prompt, and is an 'r' followed by a space and the other command-line options you use. Once the software has crashed, run "bt" at the gdb prompt, and paste the output here.Code:john-lewis-computer:~/obdgpslogger/bin jlewis$ gdb ./obdgpslogger r -s /dev/cu.CBT-DevB-1 -d /Users/jlewis/Documents/OBDGPSlogs/echo1.db
Yeah, re-writing the GUI to not suck is high on my list of stuff to do. Those buttons above the logfile box are actually part of the FLTK standard filename widget, and make it easier to cut out pieces of the filename/path [you can click on them to see what happens. I don't find it very useful, myself, but it's what's there].And just to note, the GUI does weird things spatially when resizing, and I think some buttons don't have visible labels because they're squished just above the logfile box:
Thank-you!
Gary (-;
I don't know if I did this all properly but here's what I got:
Code:(gdb) r -s /dev/cu.CBT-DevB-1 -d /Users/jlewis/Documents/OBDGPSlogs/echo1.db Starting program: /Users/jlewis/obdgpslogger/bin/obdgpslogger -s /dev/cu.CBT-DevB-1 -d /Users/jlewis/Documents/OBDGPSlogs/echo1.db Reading symbols for shared libraries . done Program received signal EXC_BAD_ACCESS, Could not access memory. Reason: KERN_PROTECTION_FAILURE at address: 0x00000000 0x90012f53 in strdup () (gdb) bt #0 0x90012f53 in strdup () #1 0x00002546 in main (argc=5, argv=0xbffffb58) at /Users/jlewis/obdgpslogger/src/logger/main.c:187
Hrm. Doesn't look like debugging symbols got built in, but there was enough of a hint to let me find what I think was the problem [getopt's shortopts didn't have a : after the 'd' option [diff]].
Try an svn update and re-build, hopefully that'll fix it
Thanks,
Gary (-;
Code:john-lewis-computer:~/obdgpslogger/bin jlewis$ ./obdgpslogger -s /dev/cu.CBT-DevB-1 -d /Users/jlewis/Documents/OBDGPSlogs/echo1.db Opening serial port /dev/cu.CBT-DevB-1, this can take a while Successfully connected to serial port. Will log obd data Creating a new trip
It made a .db and then I saw that the obdgui is also working now and used the gui to convert to a CSV which converted just fine. Looking forward to testing this while riding around and if I can help with this project let me know.
Thanks!
P.S.: Is there a "proper" way to stop a log without just killing the program?
Great stuff! Seeing people using my stuff [eg, google earth screenshots] gives me the huge huge warm fuzzies, feel free to post screenshots if you get any :-D
I'm always interested in hearing if you have any questions or suggestions, too!
Gary (-;
Well I don't have GPS capabilities but the OBD logging alone is great. Maybe I'll add GPS in the future.
