Results 21 to 30 of 32
Thread: logging suddenly stops
  1. #21
    Feb 2010
    CMakeLists.txt
    Code:
    IF("${CMAKE_SYSTEM}" MATCHES "Windows")
            ADD_DEFINITIONS(-DOBDPLATFORM_WINDOWS)
    ELSE("${CMAKE_SYSTEM}" MATCHES "Windows")
            ADD_DEFINITIONS(-DOBDPLATFORM_POSIX)
            ADD_DEFINITIONS(-DOBD_POSIX)
    ENDIF("${CMAKE_SYSTEM}" MATCHES "Windows")
    (added -DOBD_POSIX)
    I'm not sure where it's supposed to be set, but that seemed like a good place
    It's working now by just running
    obdgpslogger -m
    everything is set in /etc/obdgpslogger
  2. #22
    SuperMod - OBDII GPS Logger forum
    Mar 2009
    Los Angeles
    Ugh. Good catch. I could have stared at it all day and not seen that!
    OBD_POSIX is meant to be OBDPLATFORM_POSIX in all the places it appears in the code. Committed the fix, thank-you. svn log, svn diff
    Thanks!
    Gary (-;
    OBDGPSLogger, for logging OBDII and/or GPS data
    OBDSim, an OBDII/ELM327 software simulator
    mp3car forums: obdgpslogger, obdsim
  3. #23
    Feb 2010
    Yeah I was wondering about that, I wasn't sure if I just missed it being set or the wrong variable was being set.
    I tried messing with switching that constant but ran into problems compiling obdsim. I'll svn up and try it again in a while. I'm pretty sure it was just me messing up though.
    Thanks for the changes
  4. #24
    Mar 2009
    Los Angeles
    No, it really was just me being stupid
    If the problem still manifests, please can you show me the problems you got when compiling obdsim? Ideally, just the entire output log including a fresh build directory, "cmake .." all the way down to the end of the make?
    Thanks,
    Gary (-;
  5. #25
    Feb 2010
    updated my version, it compiled and installed correctly even with a few changes on my part(I'm also recording the speed as according to gps for comparison).
    I haven't tested it out, but I'm pretty sure the OBDPLATFORM_POSIX issue is fixed
    Thanks!
  6. #26
    Mar 2009
    Los Angeles
    Yay! And yes, your changes won't be conflicting, they just won't have any effect either :-)
    I'm always interested to see diffs if you add exciting features!
    Gary (-;
  7. #27
    Feb 2010
    I've been considering helping with this project, I'm just not sure if I'm experienced enough with C to help without getting in the way. Haven't thought of any additions though other than logging gps speed, I'll try to think something up that would be nice
  8. #28
    Mar 2009
    Los Angeles
    It's all good! I appreciate your taking the time to even look at and try this! [is it working now, by the way?]
    Gary (-;
  9. #29
    Feb 2010
    yup, working great!
    I'll send you an email with what I've done with the data so far
  10. #30
    Mar 2009
    Los Angeles
    Wow, really cool graphs that you have! I've been thinking about writing something similar.
    FWIW, you may find it useful to install libfftw3 [and the dev package], fluid and fltk, and re-run cmake. There's a tool called "obdfft" that I've written and is in SVN. It's primarily a fourier transform tool that works against obdgpslogger databases, but it also works as just a simple data visualiser for drawing a few graphs piecemeal. It seems like that's not dissimilar to what you have now.
    Gary (-;
  1. 700TSV touchscreen stops working after ~30mins
    By SpinOut123 in forum LCD/Display
    Last Post: 12-16-2009, 04:40 PM
  2. gps logging program
    By soundman98 in forum Crowdsourced Data Collection, Open Source Mapping And Routing
    Last Post: 08-19-2009, 04:40 AM
  3. New Debugging Skin, and Logging Example!
    By greenman100 in forum FB Skins
    Last Post: 04-24-2008, 12:23 AM
  4. Replies: 6
    Last Post: 05-21-2006, 02:42 PM
  5. keyboard stops working
    By corsamel in forum General Hardware Discussion
    Last Post: 03-03-2005, 02:50 PM
