Page 4 of 4 FirstFirst 1234
Results 31 to 32 of 32
Thread: logging suddenly stops
  1. #31
    Feb 2010
    I just realized the other day that I was actually running obdgpslogger from a startup script that is being run by /etc/conf.d/local.start instead of udev. It's running obdgpslogger -m though. I completely forgot about the script that's been sitting there until I went digging for a few files. It's ok though since the script also keeps each db file in a separate directory instead of merging all trips in one huge db.
  2. #32
    SuperMod - OBDII GPS Logger forum
    Mar 2009
    Los Angeles
    Probably better to use udev. That way you can hotplug after bootup without problem, and it links the chain of cause and effect correctly; obdgpslogger should be tied to your OBDII dongle plugging in, not your computer booting up
    Gary (-;
    OBDGPSLogger, for logging OBDII and/or GPS data
    OBDSim, an OBDII/ELM327 software simulator
    mp3car forums: obdgpslogger, obdsim
  1. 700TSV touchscreen stops working after ~30mins
    By SpinOut123 in forum LCD/Display
    Last Post: 12-16-2009, 04:40 PM
  2. gps logging program
    By soundman98 in forum Crowdsourced Data Collection, Open Source Mapping And Routing
    Last Post: 08-19-2009, 04:40 AM
  3. New Debugging Skin, and Logging Example!
    By greenman100 in forum FB Skins
    Last Post: 04-24-2008, 12:23 AM
  4. Replies: 6
    Last Post: 05-21-2006, 02:42 PM
  5. keyboard stops working
    By corsamel in forum General Hardware Discussion
    Last Post: 03-03-2005, 02:50 PM
