Results 1 to 7 of 7
Thread: Baudrate guessing! Also, bluetooth obdsim
    SuperMod - OBDII GPS Logger forum
    Mar 2009
    Los Angeles
    OBDGPSlogger now has a baudrate guesser. Works great for both serial dongles I have here...
    I also put bluetooth support into obdsim. Now you can run "obdsim -b" and on your linux box it'll listen for bluetooth instead of a pty.
    Gary (-;
    OBDGPSLogger, for logging OBDII and/or GPS data
    OBDSim, an OBDII/ELM327 software simulator
    mp3car forums: obdgpslogger, obdsim
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    Quote Originally Posted by chunkyks View Post
    Is this just ATZ at different baudrates until you get a valid response?
    Mar 2009
    Los Angeles
    Actually I'm using 0100, but in short... yes. It actually was just the first step, I'm now also doing baudrate upgrading [/a la/ pages 48-49 of the ELM datasheet]
    Gary (-;
    Mar 2009
    Los Angeles
    The baudrate upgrader now works too - and valgrind says that there are no possible leaks anywhere
    Woooo. It's been a good day for coding.
    Gary (-;
    Code:
    chunky@mills:~/src/tmp/obdgpslogger/build$ valgrind --leak-check=full --show-reachable=yes ../bin/obdgpslogger -b0 -B0 -t -c2 -s /dev/ttyUSB0 -l logger.txt
    ==18543== Memcheck, a memory error detector.
    ==18543== Copyright (C) 2002-2008, and GNU GPL'd, by Julian Seward et al.
    ==18543== Using LibVEX rev 1884, a library for dynamic binary translation.
    ==18543== Copyright (C) 2004-2008, and GNU GPL'd, by OpenWorks LLP.
    ==18543== Using valgrind-3.4.1-Debian, a dynamic binary instrumentation framework.
    ==18543== Copyright (C) 2000-2008, and GNU GPL'd, by Julian Seward et al.
    ==18543== For more details, rerun with: -v
    ==18543==
    Opening serial port /dev/ttyUSB0, this can take a while
    Baudrate guessing: 9600, success at 9600
    Baudrate upgrading: 38400 [68]:success, 57600 [45]:success, 115200 [22]:fail [no OK], 230400 [11]:success, 460800 [08]:fail [no ELM], 500000 [08]:success, 576000 [06]:fail [no ELM],
    Successfully connected to serial port. Will log obd data
    Couldn't open gps port on startup.
    temp=69.000000
    rpm=8048.000000
    vss=121.000000
    maf=385.279999
    Creating a new trip
    temp=69.000000
    rpm=8048.000000
    vss=121.000000
    maf=385.279999
    ==18543==
    ==18543== ERROR SUMMARY: 0 errors from 0 contexts (suppressed: 27 from 4)
    ==18543== malloc/free: in use at exit: 0 bytes in 0 blocks.
    ==18543== malloc/free: 423 allocs, 423 frees, 297,095 bytes allocated.
    ==18543== For counts of detected errors, rerun with: -v
    ==18543== All heap blocks were freed -- no leaks are possible.
    Nov 2011
    hey,
    is there a problem with bluetooth support in obdsim v 0.16 ?
    Code:
    cidou@cidou-Inspiron-9300:~/Téléchargements/obdgpslogger/build$ obdsim -b
    obdsim: invalid option -- 'b'
    cidou@cidou-Inspiron-9300:~/Téléchargements/obdgpslogger/build$ obdsim -v
    Version: 0.16
    Mar 2009
    Los Angeles
    That'll happen if you don't have the bluetooth development stuff installed. It looks for bluetooth.h the header file, so you probably just need to install libbluetooth-dev [or similar for your distro].
    Also remember to read the manpage for obdsim, as it tells you how to set up bluetooth to correctly advertise what it can do
    Gary
    Nov 2011
    Thanks, it works
