Results 1 to 3 of 3
Thread: cable not working? diagnostic procedure
    Low Bitrate eurocarpc's Avatar
    Jun 2006
    Madrid, Spain
    Hi!
    I recently bought an OBD2 to USB cable which is supposed to work with my car. I couldn't manage to get it working though. I am using Ubuntu 9.10. Before I start doing "esoteric" testing, I'd like to know better what the "diagnostic procedure" is. I tried -b 38400 and -b 9600. When I connect the cable, it automatically creates a /dev/ttyUSBX device. I'm running obdgpslogger and obdgui as root, but I also tried changing the permissions of the device to 777 and running as a regular user (the device is created as property of dialout:root)
    I read you think the Ubuntu 9.10 FTDI driver is quite broken. How can I determine if this is the problem? If I were to switch to a different version... should I go from 8.04 or 10.04?
    Thanks!
    SuperMod - OBDII GPS Logger forum
    Mar 2009
    Los Angeles
    What exactly is the device you bought? OBD GPS Logger relies on elm327 protocol to work and there are some devices out there that don't have that, it seems.
    The way to test it is by using screen or similar. Try a few likely baudrates [9600, 38400, 115200] thus:
    Code:
    screen /dev/ttyUSB0 38400
    Once screen opens, hit enter a couple times. If you see ">", that's good, that's the prompt. Your two base commands from here are "ATZ" which is "reset" and should show you a device ID, and/or "0100" which is your base "ask the car *something*"
    To exit screen, hit ctrl-a then k.
    If you see it working but then after a while things seem to stop working, or they stop working very soon, that's exactly the bug in 9.10 [although supposedly it's now fixed].
    Gary (-;
    OBDGPSLogger, for logging OBDII and/or GPS data
    OBDSim, an OBDII/ELM327 software simulator
    mp3car forums: obdgpslogger, obdsim
    Jun 2006
    Madrid, Spain
    Thanks for the quick reply. I'll come down to the car now with my laptop to try what you said.
    Hey, one suggestion: why there's no "paypal donate" in your project page? Let us pay you coffee!
  1. Hardware Review: Custom LVDS LCD Cable by MotorCity
    By Giuliano in forum The Review Palace
    Last Post: 11-04-2010, 06:51 PM
  2. Replies: 2
    Last Post: 09-03-2009, 03:55 AM
  3. Laptop TFT cable extension, strange problem
    By predator1 in forum LCD/Display
    Last Post: 06-27-2006, 05:08 AM
  4. Need help on extending the Lilliput cable
    By nthai in forum LCD/Display
    Last Post: 04-27-2005, 01:59 PM
  5. FS: 25' CAT5 IDE Cable & 3.5" PVP Player! CHEAP!
    By 1300mer in forum Classified Archive
    Last Post: 08-13-2004, 02:47 PM
Tags for this Thread
