Results 1 to 4 of 4
Thread: Building OdbGpsLogger on Linux
    Jun 2010
    I'm trying to build on ubuntu linux 10.04 (lucid). But cmake is giving me this error:
    Code:
    -- Could NOT find FLTK  (missing:  FLTK_FLUID_EXECUTABLE)
    Here is the full output:
    Code:
    ~/projects/obd2/obdgpslogger/build$ cmake ..
    -- Found gps_stream method in GPSD - assuming version 3 API
    -- Found GPSD: /usr/lib/libgps.so,/usr/lib/libgps.so
    -- Couldn't find fluid: required for building GUI
    -- Couldn't find fltk: required for building GUI
    -- Found FFTW3: /usr/lib/./libfftw3.so
    -- Couldn't find fluid: required for building obdsim fltk gui
    -- Couldn't find fltk: required for building obdsim fltk gui
    -- Found dlopen. Building dlopen sim generator
    -- Found getaddrinfo. Building socket sim generator
    -- Found LIBFTDI: /usr/lib/./libftdi.so
    -- Configuring done
    -- Generating done
    I saw this: http://www.mp3car.com/vbulletin/obdi...gpslogger.html
    i think i have all the libs installed. When i run this apt-get says everything is installed.
    Code:
    sudo apt-get install libfltk1.1-dev libfltk1.1 fltk1.1-doc fluid
    I can run fluid from command line, i get the fluid gui.
    Any help for getting cmake to find fluid would be appreciated.
    I know i dont need the GUI, but it would be nice.
    SuperMod - OBDII GPS Logger forum
    Mar 2009
    Los Angeles
    After making sure it's all installed, you probably need to purge your build dir; cmake can occasionally be a bit overzealous on its caching. Just rm -rf build, and start again.
    Gary (-;
    OBDGPSLogger, for logging OBDII and/or GPS data
    OBDSim, an OBDII/ELM327 software simulator
    mp3car forums: obdgpslogger, obdsim
    Jun 2010
    Geeze, I dunno why i didnt think of deleting the dir.
    THANKS after starting cmake with a clean dir, everything works great.
    Mar 2009
    Los Angeles
    Yay!
    Gary (-;
  1. Anyone with OBD Key software?
    By robiewp in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 11-26-2010, 12:47 PM
  2. How to get this to work on an ARM processor?
    By Bugbyte in forum OBDII GPS Logger
    Last Post: 07-20-2009, 09:45 PM
  3. The LOW Risk Linux Adventure...
    By grepzen in forum Software & Software Development
    Last Post: 11-08-2004, 09:12 PM
