Results 1 to 10 of 16
Thread: Need Help with OBDGPGLogger in Ubuntu
    Sep 2010
    Hi everyone,
    I am trying to get OBDGPSLogger to work on and am running into some issues. I have searched Google and did not find anything. I currently getting the following error:
    "Received OBD_ERROR from serial read. Exiting"
    I am not sure what I can do to fix this, is their a comand flag to fouce OBDGPSlogger to continue on?
    I am running ubuntu 10.4.1, my OBD -> USB device is a Crescent ELM327 Device and the car is a 2004 Honda Accord. I am comunicating with the car but it just quits and exits. Below I have posted both the out put of the program, and ther serial log.
    ----------- Output ---------------
    Opening serial port /dev/ttyUSB1, this can take a while
    Baudrate guessing: 9600, 38400, success at 38400
    Successfully connected to serial port. Will log obd data
    Successfully connected to gpsd. Will log gps data
    Couldn't get obd bytes for cmd 20
    here
    Error reading from serial port
    Your OBD Device claims to support PIDs:
    PID: [column] human_name
    00: [unknown] PIDs supported 00-20
    01: [dtc_cnt] Monitor status since DTCs cleared
    03: [fuelsys] Fuel system 1 and 2 status
    04: [load_pct] Calculated LOAD Value
    05: [temp] Engine Coolant Temperature
    06: [shrtft13] Short Term Fuel Trim - Bank 1,3
    07: [longft13] Long Term Fuel Trim - Bank 1,3
    0B: [map] Intake Manifold Absolute Pressure
    0C: [rpm] Engine RPM
    0D: [vss] Vehicle Speed Sensor
    0E: [sparkadv] Ignition Timing Advance for #1 Cylinder
    0F: [iat] Intake Air Temperature
    11: [throttlepos] Absolute Throttle Position
    13: [o2sloc] Location of Oxygen Sensors
    15: [o2s12] Bank 1 - Sensor 2/Bank 1 - Sensor 2 Oxygen Sensor Output Voltage / Short Term Fuel Trim
    1C: [obdsup] OBD requirements to which vehicle is designed
    20: [unknown] PIDs supported 21-40
    21: [mil_dist] Distance Travelled While MIL is Activated
    34: [lambdac11] Bank 1 - Sensor 1/Bank 1 - Sensor 1 (wide range O2S) Oxygen Sensors Equivalence Ratio (lambda) / Current
    40: [unknown] PIDs supported 41-60
    45: [tp_r] Relative Throttle Position
    -----Serial Log----------
    ATZ
    ATZ
    ELM327 v1.2a
    >0100
    ATE0
    OK
    >ATL0
    ATL0
    OK
    >ATS0
    ATS0
    >0100
    0100
    41 00 BE 3E A8 11
    >0120
    0120
    41 20 80 00 10 01
    >0140
    0140
    41 40 08 00 00 00
    >ATZ
    One time it connected and should me about 2 values and then exited, so i know it can talk to my car.
    Any help would be very much appreciated. Thanks
    SuperMod - OBDII GPS Logger forum
    Mar 2009
    Los Angeles
    here
    Ouch. I should find that debug spam and take it out
    >ATE0
    OK
    >ATS0
    ATS0
    That's kinda weird, that your device doesn't support ATS0 [which turns off spaces in the output]. It doesn't matter for my parsing process, it's just a speed boost. But still odd.
    On the other hand, I turn off echo ["ATE0"] but it appears to still be echoing things. That's almost certainly the root problem cause [other than "device claming to be ELM compliant when it's actually not"].
    Also weird is the inconsistent behaviour; the top log has an error that 0120 didn't work, but the middle log [showing supported PIDs] shows PIDs higher than 20, which it couldn't do if 0120 didn't work.
    I think I'll check my parser's logic when I get home [half an hour from now] and see if I can fix this; I *think* the root problem is it failing to parse the echo'd command.
    I also gotta write better serial logging, indicating direction.
    So... in answer... give me a couple hours. Also, what version of obdgpslogger is this? If you're not using the version in svn, please try it.
    Gary (-;
    OBDGPSLogger, for logging OBDII and/or GPS data
    OBDSim, an OBDII/ELM327 software simulator
    mp3car forums: obdgpslogger, obdsim
    Sep 2010
    I'm using the version in svn, also "obdgpslogger -v" outputs Version: 0.15.
    Also here is a link to amazon with the device.
    http://www.amazon.com/Crescent-OBD2-...4603922&sr=8-2
    Low Bitrate 2009Prius's Avatar
    Sep 2010
    Question
    I am trying out ubuntu. I can't even pass the cmake step. It looks like I am missing some critical stuff. Please help. Thanks!
    By the way is there a way to set "sudo" to default so I don't need to type it every time?
    ubuntu@ubuntu:/usr/src/obdgpslogger-trunk/build$ sudo cmake .. #
    -- The C compiler identification is GNU
    -- The CXX compiler identification is unknown
    -- Check for working C compiler: /usr/bin/gcc
    -- Check for working C compiler: /usr/bin/gcc -- works
    -- Detecting C compiler ABI info
    -- Detecting C compiler ABI info - done
    CMake Error: your CXX compiler: "CMAKE_CXX_COMPILER-NOTFOUND" was not found. Please set CMAKE_CXX_COMPILER to a valid compiler path or name.
    -- Could NOT find FLTK (missing: FLTK_LIBRARIES FLTK_INCLUDE_DIR FLTK_FLUID_EXECUTABLE)
    -- Couldn't find libgps
    -- Looking for ptsname_r
    -- Looking for ptsname_r - found
    -- Looking for include files HAVE_SIGNAL_H
    -- Looking for include files HAVE_SIGNAL_H - found
    -- Looking for sigaction
    -- Looking for sigaction - found
    -- Looking for signal
    -- Looking for signal - found
    -- Couldn't find fluid: required for building GUI
    -- Couldn't find fltk: required for building GUI
    -- Couldn't find fftw3: required for building obdfft
    -- Could NOT find ZLIB (missing: ZLIB_LIBRARIES ZLIB_INCLUDE_DIRS)
    -- Couldn't find zlib. Will not compile gzip support in obd2csv
    -- Looking for include files HAVE_SYS_SOCKET_H
    -- Looking for include files HAVE_SYS_SOCKET_H - found
    -- Looking for include files HAVE_NETDB_H
    -- Looking for include files HAVE_NETDB_H - found
    -- Looking for getaddrinfo
    -- Looking for getaddrinfo - not found.
    -- Looking for getaddrinfo - found
    -- Found getaddrinfo. Building socket sim generator
    -- Couldn't find fluid: required for building obdsim fltk gui
    -- Couldn't find fltk: required for building obdsim fltk gui
    -- Looking for dlopen
    -- Looking for dlopen - found
    -- Found dlopen. Building dlopen sim generator
    -- Looking for posix_openpt
    -- Looking for posix_openpt - found
    -- Looking for gettimeofday
    -- Looking for gettimeofday - found
    -- Looking for BTPROTO_RFCOMM
    -- Looking for BTPROTO_RFCOMM - not found.
    -- Couldn't find libftdi, required for building obdftdipty
    -- Configuring incomplete, errors occurred!
    North of the land of Hey Huns
    Jun 2004
    Westminster, MD
    You should not be running cmake as sudo, try it without?
    If removing sudo does not work, try: which g++, and set that path to the CMAKE_CXX_COMPILER environment variable.
    RevFE
    My Shop
    Mar 2009
    Los Angeles
    You need the package "build-essential" for the C and C++ compilers, in addition to fltk and libgps:
    sudo aptitude install build-essential libfltk-dev libgps-dev gpsd
    Generally sudo *isn't* permanant on purpose; the implication is that every time you run something with sudo, you're supposed to seriously consider what you're doing since it could damage the system.
    For example, the only step of building obdgpslogger that needs sudo is "make install"; the cmake and the make are done without it.
    On the other hand, to answer the question as posed: "sudo su" will give you a root prompt that you can use for multiple commands. I suggest you probably don't actually want to do this.
    Gary (-;
    Sep 2010
    Thanks! I tried to install the packages but not very successful - I am running from USB key and it seems to want to dismount it during installation, and there are somethings it can't find on the web:
    ubuntu@ubuntu:/usr/src/obdgpslogger-trunk/build$ sudo aptitude install build-essential libfltk-dev libgps-dev gpsd
    Reading package lists... Done
    Building dependency tree
    Reading state information... Done
    Initializing package states... Done
    Writing extended state information... Done
    Note: selecting "libfltk1.1-dev" instead of the
    virtual package "libfltk-dev"
    Couldn't find any package whose name or description matched "libgps-dev"
    Couldn't find any package whose name or description matched "gpsd"
    The following NEW packages will be installed:
    build-essential dpkg-dev{a} g++{a} g++-4.4{a} libdrm-dev{a} libfltk1.1{a}
    libfltk1.1-dev libgl1-mesa-dev{a} libpthread-stubs0{a}
    libpthread-stubs0-dev{a} libstdc++6-4.4-dev{a} libx11-dev{a}
    libxau-dev{a} libxcb1-dev{a} libxdmcp-dev{a} mesa-common-dev{a}
    x11proto-core-dev{a} x11proto-input-dev{a} x11proto-kb-dev{a}
    xtrans-dev{a} xz-utils{a}
    The following partially installed packages will be configured:
    initramfs-tools nvidia-current
    0 packages upgraded, 21 newly installed, 0 to remove and 0 not upgraded.
    Need to get 7,847kB/15.2MB of archives. After unpacking 39.8MB will be used.
    Do you want to continue? [Y/n/?] y
    Get:1 http://archive.ubuntu.com/ubuntu/ lucid/main x11proto-core-dev 7.0.16-1 [92.2kB]
    Get:2 http://archive.ubuntu.com/ubuntu/ lucid/main libxau-dev 1:1.0.5-1 [17.1kB]
    Get:3 http://archive.ubuntu.com/ubuntu/ lucid/main libxdmcp-dev 1:1.0.3-1 [21.2kB]
    Get:4 http://archive.ubuntu.com/ubuntu/ lucid/main x11proto-input-dev 2.0-2 [62.5kB]
    Get:5 http://archive.ubuntu.com/ubuntu/ lucid/main x11proto-kb-dev 1.0.4-1 [27.3kB]
    Get:6 http://archive.ubuntu.com/ubuntu/ lucid/main xtrans-dev 1.2.5-1 [68.5kB]
    Get:7 http://archive.ubuntu.com/ubuntu/ lucid/main libpthread-stubs0 0.3-2 [3,196B]
    Get:8 http://archive.ubuntu.com/ubuntu/ lucid/main libpthread-stubs0-dev 0.3-2 [2,414B]
    Get:9 http://archive.ubuntu.com/ubuntu/ lucid/main libxcb1-dev 1.5-2 [73.8kB]
    Get:10 http://archive.ubuntu.com/ubuntu/ lucid/main libx11-dev 2:1.3.2-1ubuntu3 [3,505kB]
    Get:11 http://archive.ubuntu.com/ubuntu/ lucid/main libdrm-dev 2.4.18-1ubuntu3 [515kB]
    Get:12 http://archive.ubuntu.com/ubuntu/ lucid/main libfltk1.1 1.1.10-2 [463kB]
    Get:13 http://archive.ubuntu.com/ubuntu/ lucid/main libfltk1.1-dev 1.1.10-2 [626kB]
    Get:14 http://archive.ubuntu.com/ubuntu/ lucid-updates/main mesa-common-dev 7.7.1-1ubuntu3 [2,339kB]
    Get:15 http://archive.ubuntu.com/ubuntu/ lucid-updates/main libgl1-mesa-dev 7.7.1-1ubuntu3 [31.5kB]
    Err cdrom://Ubuntu 10.04.1 LTS _Lucid Lynx_ - Release i386 (20100816.1)/ lucid/main libstdc++6-4.4-dev 4.4.3-4ubuntu5
    Unable to unmount the CD-ROM in /cdrom/, it may still be in use.
    Get:16 http://archive.ubuntu.com/ubuntu/ lucid/main libstdc++6-4.4-dev 4.4.3-4ubuntu5 [1,491kB]
    Err cdrom://Ubuntu 10.04.1 LTS _Lucid Lynx_ - Release i386 (20100816.1)/ lucid/main g++-4.4 4.4.3-4ubuntu5
    Get:17 http://archive.ubuntu.com/ubuntu/ lucid/main g++-4.4 4.4.3-4ubuntu5 [4,950kB]
    Err cdrom://Ubuntu 10.04.1 LTS _Lucid Lynx_ - Release i386 (20100816.1)/ lucid/main g++ 4:4.4.3-1ubuntu1
    Get:18 http://archive.ubuntu.com/ubuntu/ lucid/main g++ 4:4.4.3-1ubuntu1 [1,442B]
    Err cdrom://Ubuntu 10.04.1 LTS _Lucid Lynx_ - Release i386 (20100816.1)/ lucid/main xz-utils 4.999.9beta+20091116-1
    Get:19 http://archive.ubuntu.com/ubuntu/ lucid/main xz-utils 4.999.9beta+20091116-1 [228kB]
    Err cdrom://Ubuntu 10.04.1 LTS _Lucid Lynx_ - Release i386 (20100816.1)/ lucid/main dpkg-dev 1.15.5.6ubuntu4.1
    Err http://archive.ubuntu.com/ubuntu/ lucid-updates/main dpkg-dev 1.15.5.6ubuntu4.1
    404 Not Found [IP: 91.189.92.166 80]
    Err cdrom://Ubuntu 10.04.1 LTS _Lucid Lynx_ - Release i386 (20100816.1)/ lucid/main build-essential 11.4build1
    Get:20 http://archive.ubuntu.com/ubuntu/ lucid/main build-essential 11.4build1 [7,278B]
    Fetched 14.5MB in 2min 10s (111kB/s)
    Preconfiguring packages ...
    Selecting previously deselected package x11proto-core-dev.
    (Reading database ... 129637 files and directories currently installed.)
    Unpacking x11proto-core-dev (from .../x11proto-core-dev_7.0.16-1_all.deb) ...
    Selecting previously deselected package libxau-dev.
    Unpacking libxau-dev (from .../libxau-dev_1%3a1.0.5-1_i386.deb) ...
    Selecting previously deselected package libxdmcp-dev.
    Unpacking libxdmcp-dev (from .../libxdmcp-dev_1%3a1.0.3-1_i386.deb) ...
    Selecting previously deselected package x11proto-input-dev.
    Unpacking x11proto-input-dev (from .../x11proto-input-dev_2.0-2_all.deb) ...
    Selecting previously deselected package x11proto-kb-dev.
    Unpacking x11proto-kb-dev (from .../x11proto-kb-dev_1.0.4-1_all.deb) ...
    Selecting previously deselected package xtrans-dev.
    Unpacking xtrans-dev (from .../xtrans-dev_1.2.5-1_all.deb) ...
    Selecting previously deselected package libpthread-stubs0.
    Unpacking libpthread-stubs0 (from .../libpthread-stubs0_0.3-2_i386.deb) ...
    Selecting previously deselected package libpthread-stubs0-dev.
    Unpacking libpthread-stubs0-dev (from .../libpthread-stubs0-dev_0.3-2_i386.deb) ...
    Selecting previously deselected package libxcb1-dev.
    Unpacking libxcb1-dev (from .../libxcb1-dev_1.5-2_i386.deb) ...
    Selecting previously deselected package libx11-dev.
    Unpacking libx11-dev (from .../libx11-dev_2%3a1.3.2-1ubuntu3_i386.deb) ...
    Selecting previously deselected package libstdc++6-4.4-dev.
    Unpacking libstdc++6-4.4-dev (from .../libstdc++6-4.4-dev_4.4.3-4ubuntu5_i386.deb) ...
    Selecting previously deselected package g++-4.4.
    Unpacking g++-4.4 (from .../g++-4.4_4.4.3-4ubuntu5_i386.deb) ...
    Selecting previously deselected package g++.
    Unpacking g++ (from .../g++_4%3a4.4.3-1ubuntu1_i386.deb) ...
    Selecting previously deselected package libdrm-dev.
    Unpacking libdrm-dev (from .../libdrm-dev_2.4.18-1ubuntu3_i386.deb) ...
    Replaced by files in installed package linux-libc-dev ...
    Selecting previously deselected package libfltk1.1.
    Unpacking libfltk1.1 (from .../libfltk1.1_1.1.10-2_i386.deb) ...
    Selecting previously deselected package libfltk1.1-dev.
    Unpacking libfltk1.1-dev (from .../libfltk1.1-dev_1.1.10-2_i386.deb) ...
    Selecting previously deselected package mesa-common-dev.
    Unpacking mesa-common-dev (from .../mesa-common-dev_7.7.1-1ubuntu3_i386.deb) ...
    Selecting previously deselected package libgl1-mesa-dev.
    Unpacking libgl1-mesa-dev (from .../libgl1-mesa-dev_7.7.1-1ubuntu3_i386.deb) ...
    Selecting previously deselected package xz-utils.
    Unpacking xz-utils (from .../xz-utils_4.999.9beta+20091116-1_i386.deb) ...
    Processing triggers for man-db ...
    Setting up initramfs-tools (0.92bubuntu78) ...
    update-initramfs: deferring update (trigger activated)
    cp: cannot stat `/vmlinuz': No such file or directory
    dpkg: error processing initramfs-tools (--configure):
    subprocess installed post-installation script returned error exit status 1
    Setting up nvidia-current (195.36.24-0ubuntu1~10.04) ...
    dpkg: error processing nvidia-current (--configure):
    Setting up x11proto-core-dev (7.0.16-1) ...
    Setting up libxau-dev (1:1.0.5-1) ...
    Setting up libxdmcp-dev (1:1.0.3-1) ...
    Setting up x11proto-input-dev (2.0-2) ...
    Setting up x11proto-kb-dev (1.0.4-1) ...
    Setting up xtrans-dev (1.2.5-1) ...
    Setting up libpthread-stubs0 (0.3-2) ...
    Setting up libpthread-stubs0-dev (0.3-2) ...
    Setting up libxcb1-dev (1.5-2) ...
    Setting up libx11-dev (2:1.3.2-1ubuntu3) ...
    Setting up libdrm-dev (2.4.18-1ubuntu3) ...
    Setting up libfltk1.1 (1.1.10-2) ...
    Setting up libfltk1.1-dev (1.1.10-2) ...
    Setting up mesa-common-dev (7.7.1-1ubuntu3) ...
    Setting up libgl1-mesa-dev (7.7.1-1ubuntu3) ...
    Setting up xz-utils (4.999.9beta+20091116-1) ...
    Setting up libstdc++6-4.4-dev (4.4.3-4ubuntu5) ...
    Setting up g++-4.4 (4.4.3-4ubuntu5) ...
    Setting up g++ (4:4.4.3-1ubuntu1) ...
    update-alternatives: using /usr/bin/g++ to provide /usr/bin/c++ (c++) in auto mode.
    Processing triggers for python-gmenu ...
    Rebuilding /usr/share/applications/desktop.en_US.utf8.cache...
    Processing triggers for libc-bin ...
    ldconfig deferred processing now taking place
    Processing triggers for python-support ...
    Errors were encountered while processing:
    initramfs-tools
    nvidia-current
    E: Failed to fetch http://archive.ubuntu.com/ubuntu/poo...tu4.1_all.deb: 404 Not Found [IP: 91.189.92.166 80]
    E: Sub-process /usr/bin/dpkg returned an error code (1)
    A package failed to install. Trying to recover:
    initramfs-tools
    nvidia-current
    Reading extended state information
    Mar 2009
    Los Angeles
    Weird. Honestly I suspect it's a new version hasn't made it to the mirror you're using yet. Try re-running:
    "sudo aptitude update && sudo aptitude safe-upgrade" and then run the same command again, "sudo aptitude install build-essential libfltk-dev libgps-dev gpsd"
    Also, open the package repository manager, and take out the ubuntu CD stuff. You might even want to try switching mirrors.
    Gary (-;
    Sep 2010
    Question
    Quote Originally Posted by chunkyks View Post
    Gary (-;
    Thanks for being so patient guiding me along the way!
    It wasn't warning free yet but I got one small step closer. I think part of the reason was the computer needs to be restarted after some updates. Earlier when I just started using ubuntu there was a prompt to update drivers. I tried to update the video (nvidia) driver using the gui app and it eventually crashed. When I ran
    there were again some complaints about nvidia and also warnings of low disk space. I restarted the computer anyway and proceeded to run
    Now the only thing it can't find seems to be the GPS stuff:
    Any idea?
    Mar 2009
    Los Angeles
    Weird that gpsd and libgps-dev are missing. Maybe you could check your package manager and make sure the extra repositories are enabled?
    Gary (-;
  1. Lilliput touch with Ubuntu?
    By sansbury in forum LCD/Display
    Last Post: 06-13-2011, 11:20 AM
  2. Have Questions on Linux and Ubuntu Linux.
    By HiJackZX1 in forum Linux
    Last Post: 03-05-2010, 10:59 AM
  3. Ubuntu Mobile - the next gen Car PC frontend!?
    By wywywywy in forum Unix, Linux, BSD, Etc
    Last Post: 06-23-2009, 12:31 PM
  4. Ubuntu on Mac Mini (sleep issues)
    By natedawgg in forum Linux
    Last Post: 02-06-2009, 02:28 PM
  5. Ubuntu Vs. XP...
    By ilovemyhonda in forum Linux
    Last Post: 10-04-2008, 01:47 PM
