Results 11 to 20 of 25
Thread: cygwin setup questions
  1. #11
    SuperMod - OBDII GPS Logger forum
    Mar 2009
    Los Angeles
    Ugh. That was why I had you install fltk-gdi, so that you wouldn't need an x server. Erm, I'll look later at the "right" way to solve that. In the meantime, the hokey solution is to install the cygwin x server and just use that :-)
    Gary (-;
    OBDGPSLogger, for logging OBDII and/or GPS data
    OBDSim, an OBDII/ELM327 software simulator
    mp3car forums: obdgpslogger, obdsim
  2. #12
    Low Bitrate 2009Prius's Avatar
    Sep 2010
    So what package(s) contain the x server? "X11/xorg-server"? Thanks!
  3. #13
    Mar 2009
    Los Angeles
    Hrm. So I can't figure out the fltk-gdi thing from within cygwin.
    From cygwin's setup, choose "xinit" which will install all the stuff you need. Then go into your start menu's "Cygwin X", and start the X server. You'll get a terminal window that you can use.
    Whenever you want a new terminal window and cygwin/X is running, you'll want to click on the X in the system tray and choose Applications->Xterm [which is actually highly preferable to the default cygwin terminal anyway]
    Gary (-;
  4. #14
    Sep 2010
    Question Xterm worked! next step...
    Quote Originally Posted by chunkyks View Post
    Gary (-;
    Xterm worked! Thanks so much!
    Now how do I get obdgui to work with obdsim? I tried running obdsim from one xterm and then running obdgui from another one. All the gauges are grayed out. I was hoping to see some fake data being fed from the obdsim to obdgui...
  5. #15
    Mar 2009
    Los Angeles
    Did you do "make install" ?
    Assuming you did, when you run obdsim it says something like:
    Code:
    SimPort name: /dev/tty1
    In obdgui, edit the "OBD Device" box to say the simport [yours is probably also /dev/tty1] and click "Go"
    Gary (-;
  6. #16
    Sep 2010
    Question Path?
    Code:
    Gary (-;
    Yes obdsim says
    and I entered the same into obdgui and clicked "Go". Something ("Starting" maybe) flashed really fast behind the "Go" button and then disappeared. All gauges still remain grayed out.
    I also realized that part of the problem maybe the path is not set to the
    /usr/src/obdgpslogger-0.15/bin
    directory. I had to run
    ./obdgui
    not just
    obdgui
    Then I found $PATH contains both unix and Windows paths. Very strange.
    Oops I missed the "make install" until now - thought it was optional. Did a quick try:
    $ make install #
    /bin/sh: line 0: cd: /obdgpslogger-0.15/build: No such file or directory
    make[2]: *** [libs/sqlite3/CMakeFiles/cksqlite.dir/depend] Error 1
    make[1]: *** [libs/sqlite3/CMakeFiles/cksqlite.dir/all] Error 2
    make: *** [all] Error 2
    Looks like more issues to deal with...
  7. #17
    Mar 2009
    Los Angeles
    ./obdgui
    not just
    obdgui
    Yes, that's what causes obdgui to fail like that. Without the make install part:
    Code:
    export PATH=/usr/src/obdgpslogger-0.15/bin:$PATH
    obdgui
    I'm not sure why that make install is failing; did you move the obdgpslogger source directory after building? If you did, you'll need to re-run cmake.
    Gary (-;
  8. #18
    Sep 2010
    One little step forward
    Code:
    obdgui
    Gary (-;
    That helped! After setting the path I got
    Code:
    $ ../bin/obdsim
    Successfully initialised obdsim, entering main loop
    Reset
    Reset
    Echo disabled
    Linefeed disabled
    Spaces disabled
    Reset
    Reset
    Echo disabled
    Linefeed disabled
    Spaces disabled
    Reset
    Reset
    Echo disabled
    Linefeed disabled
    Spaces disabled
    Reset
    pressing the "Go" three times. So I guess obdgui is talking to obdsim now. Gauges are still grayed out though.
    I did move the directory. I will try recompile later on the newer version of code. Thanks!
  9. #19
    Mar 2009
    Los Angeles
    Technically, what's actually happening is that obdsim and obdgui never directly communicate. obdgui launches the separate obdgpslogger binary, and that's what communicates with the sim.
    Could you go into window->raw output and check the checkbox, and paste what it's saying when you run it?
    Also, could you run obdsim with "--logfile=seriallog.txt" and see what that contains?
    Sorry this is all so much effort! Normally things are a lot simpler :-(
    Gary (-;
  10. #20
    Sep 2010
    Smile It's working! Thank you so much!
    Thanks for so patiently answering all my questions! It finally worked!
    At some point my hard drive ran out of space, so I decided to give it a clean start. I cleaned out old junks to make room on the hard drive. I wiped cygwin and reinstalled it with Xinit but without fltk. I downloaded most recent code using svn. Initially obdgui was not built until I realized and added fltk. Then it just worked. The obdsim echos something like
    SimPort name: /dev/tty2
    10.000000 seconds. 0 samples, 0 queries. 0.00 s/s, 0.00 q/s
    Reset
    10.519000 seconds. 0 samples, 1 queries. 0.00 s/s, 0.10 q/s
    Echo disabled
    Linefeed disabled
    Spaces disabled
    10.143000 seconds. 50 samples, 53 queries. 4.93 s/s, 5.23 q/s
    10.145000 seconds. 50 samples, 50 queries. 4.93 s/s, 4.93 q/s
    10.073000 seconds. 49 samples, 49 queries. 4.86 s/s, 4.86 q/s
    10.130000 seconds. 50 samples, 50 queries. 4.94 s/s, 4.94 q/s
    10.195000 seconds. 50 samples, 50 queries. 4.90 s/s, 4.90 q/s
    10.175000 seconds. 50 samples, 50 queries. 4.91 s/s, 4.91 q/s
    and all five gauges on obdgui show numbers and moving needles.
    I am so happy! Thank you so much!
    Questions for next steps:
    1. The cygwin install still added a lot of Windows paths into $PATH. I used
      Code:
      export PATH=/usr/local/bin:/usr/bin:/bin
      to clean it up. Is that OK?
    2. GPS and FFT are still missing.
    3. Hardware: I am contemplating between OBDPro USB Scantool and OBDLink Multiprotocol OBD-II by ScanTool. Any preference between the two?
    Thanks again!
  1. Fuse setup questions!
    By HiJackZX1 in forum General Hardware Discussion
    Last Post: 05-26-2008, 08:52 PM
  2. Alpine setup questions
    By mattman in forum Car Audio
    Last Post: 05-19-2008, 05:57 AM
  3. Setup questions
    By hoodlum in forum Newbie
    Last Post: 05-07-2006, 10:39 PM
  4. Doing a carpc setup, questions/help
    By Punisher in forum General MP3Car Discussion
    Last Post: 08-28-2005, 12:44 PM
  5. I just have some general setup questions
    By thaladyzman in forum General MP3Car Discussion
    Last Post: 02-15-2003, 02:26 PM
