Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Need Help (build OBDGPSloggers on Ubuntu)
  1. #11
    Jan 2012
    How do you get this problem solved?
    I see in the following message that you have solved this problem.
    However, when I type the command: "./obdsim -b", I have similar output:
    SimPort name: Not yet connected
    My phone and the laptop are already paired.
    Would you please tell me how do you get this problem solved? Thanks.
    Quote Originally Posted by markya0616 View Post
    By the way I found after "./obdsim -b"
    Code:
    Successfully initialised obdsim, entering main loop
    10.000060 seconds. 0 samples, 0 queries. 0.00 s/s, 0.00 q/s
    10.000163 seconds. 0 samples, 0 queries. 0.00 s/s, 0.00 q/s
    10.000296 seconds. 0 samples, 0 queries. 0.00 s/s, 0.00 q/s
    10.000085 seconds. 0 samples, 0 queries. 0.00 s/s, 0.00 q/s
    10.000107 seconds. 0 samples, 0 queries. 0.00 s/s, 0.00 q/s
    10.000322 seconds. 0 samples, 0 queries. 0.00 s/s, 0.00 q/s
    10.001037 seconds. 0 samples, 0 queries. 0.00 s/s, 0.00 q/s
    10.000051 seconds. 0 samples, 0 queries. 0.00 s/s, 0.00 q/s
    10.000323 seconds. 0 samples, 0 queries. 0.00 s/s, 0.00 q/s
    10.000080 seconds. 0 samples, 0 queries. 0.00 s/s, 0.00 q/s
    10.000852 seconds. 0 samples, 0 queries. 0.00 s/s, 0.00 q/s
    10.000146 seconds. 0 samples, 0 queries. 0.00 s/s, 0.00 q/s
    "SimPort name: Not yet connected" means not connect to bluetooth port?
  2. #12
    SuperMod - OBDII GPS Logger forum
    Mar 2009
    Los Angeles
    You probably need to make sure that you've configured your bluetooth port to advertise it's capable of serial comms. It's described in the "bluetooth" section of the manpage:
    http://icculus.org/obdgpslogger/manp...der/obdsim.txt
    Gary (-;
    OBDGPSLogger, for logging OBDII and/or GPS data
    OBDSim, an OBDII/ELM327 software simulator
    mp3car forums: obdgpslogger, obdsim
  1. Bugbyte's iPad Connected Car Install
    By Bugbyte in forum Worklogs
    Last Post: 06-17-2013, 03:43 PM
  2. Lilliput touch with Ubuntu?
    By sansbury in forum LCD/Display
    Last Post: 06-13-2011, 11:20 AM
  3. My First Build
    By romont2001 in forum Newbie
    Last Post: 02-28-2010, 08:24 PM
  4. My first build plans, criticism welcomed
    By an0maly in forum Newbie
    Last Post: 01-02-2010, 07:13 PM
  5. Replies: 4
    Last Post: 06-18-2006, 04:18 PM
