Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: BU-353, gpsd, and obdgpslogger?
  1. #11
    Low Bitrate 2009Prius's Avatar
    Sep 2010
    Question
    Made a small step forward. After some security updates ubuntu asked to restart. After restart the obdgui started to show the GPS info again! However after logging for maybe 5 or 10 minutes the gps.lon gps.lat gps.alt
    got stuck at the same values, no longer changing, even though I was driving and tangoGPS showed the correct location on the map all the way, so GPS was working, just not passing the info to obdgpslogger correctly. Any suggestions?
  2. #12
    Sep 2010
    Question
    Tried a couple of more times. obdgpslogger still only records the first few minutes of GPS coordinates and then the values got stuck at the same place. I also tried without running tangoGPS and the result is the same. Still waiting for some suggestions....
  1. Getting OBDGPSlogger to run on the Sheeva Plug
    By Bugbyte in forum OBDII GPS Logger
    Last Post: 04-22-2010, 04:49 PM
  2. On gpsd, obdgpslogger, and udev hotplug
    By chunkyks in forum OBDII GPS Logger
    Last Post: 10-21-2009, 10:11 AM
Tags for this Thread
