Results 1 to 10 of 12
Thread: BU-353, gpsd, and obdgpslogger?
    Low Bitrate 2009Prius's Avatar
    Sep 2010
    Question BU-353, gpsd, and obdgpslogger?
    Trying to make the GPS to work. Some issues:
    1. The connection to BU-353 seems hit-or-miss. I use
    Code:
    gpsd /dev/ttyUSB0 -b -n
    and tangoGPS software to check it out. Sometimes it works. Sometimes it doesn't.
    2. The GPS coordinates show up fine in the obdgui window. However obdgui shows an error message when I close the window:
    Code:
    Couldn't SIGTERM gpsd: No such process
    and the log doesn't get saved (converted csv file only has the header line). I have to press Ctrl^C to bring back the prompt.
    Please help! Thanks!
    SuperMod - OBDII GPS Logger forum
    Mar 2009
    Los Angeles
    Running it from the gui really kinda sucks, I mostly put that in there for OSX. It's much better to get gpsd configured to work with udev. Which version of ubuntu are you using, remind me?
    IIRC, you can start with "sudo dpkg-reconfigure gpsd" which lets you configure autostart.
    Gary (-;
    OBDGPSLogger, for logging OBDII and/or GPS data
    OBDSim, an OBDII/ELM327 software simulator
    mp3car forums: obdgpslogger, obdsim
    Sep 2010
    Quote Originally Posted by chunkyks View Post
    Gary (-;
    Thanks! It's Ubuntu 10.04 LTS. Not sure what LTS is. It was downloaded from the Ubuntu web site not too long ago.
    Code:
    helped. I just plug in the GPS and start tangoGPS and wait a short time for the coordinates to show up.
    obdgui still recognizes the coordinates and gpsd did not complain when obdgui exits.
    Thanks for the help!
    Mar 2009
    Los Angeles
    "LTS" is long-term support; most ubuntu distributions are only supported for a couple years, wheras LTS flavors are supported for more than that [can't remember the exact figures].
    If you're just a regular joe, then you probably want to be updating to new versions whenever they're released [or at least a few weeks later, in case of teething problems - 9.10 had a huge number of teething issues at release]
    So... yay! It sounds like you're up and running now?
    Gary (-;
    Sep 2010
    Thanks! Yes I usually wait until the initial bugs got fixed before jumping to a new version.
    So far I am still using the obdsim as supplied. I would like to add some more Prius specific parameters in the software before buying an OBD-USB device and run it for real. I will start a new thread on that soon.
    Mar 2009
    Los Angeles
    Yeah, start a new thread. It'll galvanise me into doing a couple things, probably...
    Gary (-;
    Sep 2010
    Question
    Gary (-;
    Done. See
    http://www.mp3car.com/vbulletin/obdi...questions.html
    By the way is there any particular way I should unplug the GPS from the laptop, i.e. some kind of "safely remove hardware" thing? Thanks!
    Sep 2010
    Question First GPS road test not good
    Quote Originally Posted by 2009Prius View Post
    Code:
    obdgui still recognizes the coordinates and gpsd did not complain when obdgui exits....
    Well I don't know what may have changed but today when I tried a road test for the first time it did not go smoothly. BU-353 red LED was blinking so I know it's getting the coordinates. But tangoGPS did not show the car's movement on the map and obdgui shows all zeros for the GPS coordinates. I quit and restarted tangoGPS which fixed one problem: now it showed the correct location on the map. I quit and restarted obdgui multiple times but it still showed all zeros. I just converted the db file to csv file and the log has all zeros as well. Somehow the GPS data is not picked up by obdgpslogger. Any suggestions?
    PS. I have been unplugging and plugging the BU-353 without doing any "safely remove hardware" thing since I couldn't find any in the Ubuntu. Not sure if this is an issue or not. At least tangoGPS did pick up the data after restarting the application.
    Sep 2010
    Question
    Tested some more: even tangoGPS failed to pick up the GPS data once, but it does work most of the time. I am still having trouble getting the GPS data to show up in obdgui.
    Sep 2010
    This morning tangoGPS failed to get the data again even though BU-353 was blinking. odbgpsgui still shows all zeros. Is there some other way to verify that gpsd is working?
  1. Getting OBDGPSlogger to run on the Sheeva Plug
    By Bugbyte in forum OBDII GPS Logger
    Last Post: 04-22-2010, 05:49 PM
  2. On gpsd, obdgpslogger, and udev hotplug
    By chunkyks in forum OBDII GPS Logger
    Last Post: 10-21-2009, 11:11 AM
Tags for this Thread
