Results 11 to 20 of 28
Thread: [Android Development] Can OBDSim help me ?
  1. #11
    Jan 2012
    Austria
    Hey, thanks for your quick answer!
    Ok i tried but i failed Don't know what I'm doing wrog.
    What I've done:
    1) Unpair phone and Laptop
    2) Reboot both
    3)
    Code:
    fabs@ubuntu:~$ hcitool dev
    Devices:
    	hci0	40:2C:F4:6B:2C:C0
    fabs@ubuntu:~$ sudo rfcomm bind 0 40:2C:F4:6B:2C:C0 1
    [sudo] password for fabs:
    fabs@ubuntu:~$ sudo sdptool add SP
    Serial Port service registered
    4) Then paired Phone and Laptop
    5)
    Code:
    fabs@ubuntu:~$ obdsim -b
    SimPort name: Unknown
    Successfully initialised obdsim, entering main loop
    10.000637 seconds. 0 samples, 0 queries. 0.00 s/s, 0.00 q/s
    6) Start Torque or OBD II Reader at Phone -> send Command.
    Ubuntu gets the command because of the ubuntu popup- report that my device [...] tried to acess the service [...] would you allow this ....
    But it did not arrive at the simulator and of course i did not get an answer.
    I've no idea what went wrong.
    Thanks in advice.
    Fabs
  2. #12
    Jan 2012
    help needed OBDSIM Bluetooth
    Hi Mods ... I am working on a similiar kind of application like TORQUE ; I followed all the instruction and installed in my Ubuntu 11.10
    But the app(for eg torque) is not able to read the ifo from my PC ; below are the terminal output
    brightson@ubuntu:/host/brightson/OBD/obdgpslogger$ obdsim -b
    10.000447 seconds. 0 samples, 0 queries. 0.00 s/s, 0.00 q/s
    10.000244 seconds. 0 samples, 0 queries. 0.00 s/s, 0.00 q/s
    10.000603 seconds. 0 samples, 0 queries. 0.00 s/s, 0.00 q/s
    10.000394 seconds. 0 samples, 0 queries. 0.00 s/s, 0.00 q/s
    you help is highly appreciated .. thanks
  3. #13
    Jan 2012
    Austria
    No one any idea?
  4. #14
    Mar 2012
    Android app on windows communication with obdsim
    Quote Originally Posted by chunkyks View Post
    Short version: no, that's what 0100, 0120, 0140, etc are for
    Long version: It's up to the individual generators which PIDs they support. Logger, for example, reports a list of the PIDs available in the database it's using.
    This database has one set of PIDs: http://icculus.org/obdgpslogger/exam...treettriple.db
    This has completely another: http://icculus.org/obdgpslogger/exam...010/ces2010.db
    The right thing to do is have your code always use 0100 first, to get a list of supported PIDs from the vehicle/sim, and then decide what to do from there.
    Gary (-;
    Hey Gary,
    Thank you for this simulator.......and I have some questions...I am trying to create an android application in windows.I have dowloaded all the obdsim necessities and com0com also.Its working fine.I wanted to know if bluetooth communication is possible using the simulator,if I want to send data into my android device?I have gone through the data and its still not clear since i am an amateur.Plz help
  5. #15
    SuperMod - OBDII GPS Logger forum
    Mar 2009
    Los Angeles
    Bluetooth is only currently supported on Linux, using bluetooth.h. A windows port wouldn't be hard, but nowadays it's usually easier to just install linux on a VM or nearby laptop...
    Thanks,
    Gary (-;
    OBDGPSLogger, for logging OBDII and/or GPS data
    OBDSim, an OBDII/ELM327 software simulator
    mp3car forums: obdgpslogger, obdsim
  6. #16
    Mar 2012
    Thank you for the answer gary but I cannot have Linux on VM since my system is not fast.But could you help with the windows bluetooth?I have downloaded everything and its working fine.OBDSIM.exe and I am getting the values
    10.011001 seconds. 0 samples, 0 queries. 0.00 s/s, 0.00 q/s
    But how do I sent queries and how can I connect to my Android Mobile??
  7. #17
    Mar 2012
    Plz Helppppppppppp
  8. #18
    Mar 2009
    Los Angeles
    I don't currently have any way to do bluetooth in windows. I'm sure that a bit of googling would turn up what's probably the best bet:
    See if you can find a bluetooth widget/app/whatever that opens a COM port to windows, and exposes an RFCOMM interface via bluetooth. Then attach obdsim to that COM port. It almost certainly exists, I've just never gone looking for it...
    Alternatively, I'm always accepting patches. If anyone wants to code up the bluetooth windows stack stuff, I'd be more than happy to include it...
    Gary
  9. #19
    Mar 2012
    Hey Gary..Thank you for taking time and answering the question...I have a few doubts ..I have opened a Bluetooth comport which is an incoming one.But I still didnt understand how to connect this to my android device.I am also getting default values like 10.011001 seconds. 0 samples, 0 queries. 0.00 s/s, 0.00 q/s . So how can I get different values. I tried chaning generators but I get the same values.Then the other problem is I have seen that there is also a GUI from this link http://icculus.org/obdgpslogger/obdsim.html .But I dont see it anywhere here. Could you answer these questions and clear it out plz
  10. #20
    Mar 2009
    Los Angeles
    Quote Originally Posted by androidgeek View Post
    Can you explain what you did? I don't know how you would have created a bluetooth comport?
    That's simply output, letting you know how many times the sim has communicated with the OBDII device. The numbers become useful once you're actually able to communicate between the OBDII app and the sim. ["samples" is how many OBDII PID requests there were. "queries" is total number of things communicated; queries includes things like AT commands, wheras samples doesn't]. That you're always seeing zeros just means that a connection isn't getting made.
    That gui is simply one of the generators, called gui_fltk. It should be the default on windows if it's compiled in [did you build obdsim yourself? if so, you'll need to have included FLTK support for the GUI to be there. If you downloaded the binary from my site, it comes with gui_fltk statically linked]. You can tell if it's compiled in by using "--list-generators"; if it's available, "gui_fltk" will be listed there.
    Gary (-;
  1. OBDSim help?
    By preet in forum OBDSim
    Last Post: 05-18-2011, 01:29 AM
  2. OBDsim with FB
    By nemo1 in forum OBDSim
    Last Post: 10-25-2010, 10:33 PM
  3. What is OBDSim?
    By chunkyks in forum OBDSim
    Last Post: 09-20-2010, 03:26 PM
  4. CF with my OBDSim
    By chunkyks in forum Centrafuse
    Last Post: 09-15-2010, 03:02 PM
  5. New Toy: obdsim
    By chunkyks in forum OBDII GPS Logger
    Last Post: 07-02-2009, 12:04 PM
