Results 1 to 6 of 6
Thread: Quick Question (USB, IR LEDs)
    May 2006
    Perth, Australia
    Question Quick Question (USB, IR LEDs)
    A quick question for the electrical wizards out there;
    I'm making a friend a neat little IR illuminator for their webcam, and I want to know, would I be able to pull enough power out of a USB port to power it?
    It'll just be 15-20 IR LEDs powered off of a single USB port.
    Doesn't have to be insanely bright, just needs to work.
    Any issues in the design?
    Thanks ahead.
    Variable Bitrate kamikaze2112's Avatar
    Feb 2005
    Barrie Ontario
    you can get 500mA MAX out of a USB port @ 5 VDC. Depending on how much current your IR leds draw, you might be able to get some powered off the USB bus
    May 2006
    Perth, Australia
    I've got no idea how much current they draw.
    I have the following info (probably useless though);
    - 5mm diameter
    - Dark blue lens
    - 940 nm Intensity
    - 20 degrees (this is under a heading of the theta symbol, followed by "1/2")
    That's all the info I can get.
    They're from Dick Smith Electronics (one of Australia's "leading" electronic component suppliers)
    Takes it in the Rear kevinlekiller's Avatar
    Dec 1969
    Where the penguins and polar bears live.
    A 3 or 5mm uv l.e.d. is 20ma forward current , so thats 400ma , then you need to remember the cam takes power. Maybe use a powered usb hub?
    Dec 1969
    Oh wait you wrote IR , then its about 100ma each. wich is 2 amps for 20.
    May 2006
    Perth, Australia
    So I could only power 5.
    Damn, that's not overly useful then. Or is it?
    A powerpack is something like a $20 addition.
    Still cheaper than buying one, the only ones I can find on eBay are for surveillance (and would be too powerful thus flooding the webcam's image sensor with light).
    Would anyone know of any suitable products?
  1. MCE keyboard with usb IR
    By hoodlum in forum Input Devices
    Last Post: 10-26-2006, 12:24 PM
  2. Sound Blaster External USB Question
    By nirvanades in forum General Hardware Discussion
    Last Post: 06-16-2006, 02:09 AM
  3. USB power question
    By maxxell in forum General Hardware Discussion
    Last Post: 04-13-2006, 04:06 PM
  4. Quick question regarding usb hubs
    By Sonicxtacy02 in forum General Hardware Discussion
    Last Post: 04-12-2005, 09:18 PM
  5. quick question
    By septicdeath in forum Power Supplies
    Last Post: 06-30-2004, 11:57 AM
