Results 1 to 9 of 9
Thread: Math problem...need a little help
    Apr 2005
    Queens, New York
    OK well here is the question:
    Give to examples of sets which can be put in a one to one correspondence with the following sets:
    a. {a , e, i, o, u}
    b. {5, 10, 15, ...}
    answers to be:
    2, 4, 6,...
    7, 14, 21....
    BUT I dont get part A
    Anybody wanna take a shot... I have noooo clue ..
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
    mezz64's Avatar
    Nov 2004
    PA
    Blog Entries
    1
    In mathematics, one-to-one correspondence refers to a situation in which the members of one set (call it A) can be evenly matched with the members of a second set (call it B). Evenly matched means that each member of A is paired with one and only one member of B, each member of B is paired with one and only one member of A, and none of the members from either set are left unpaired. The result is that every member of A is paired with exactly one member of B, and every member of B is paired with exactly one member of A. In terms of ordered pairs (a,b), where a is a member of A and b is a member of B, no two ordered pairs created by this matching process have the same first element and no two have the same second element. When this type of matching can be shown to exist, mathematicians say that "a one-to-one correspondence exists between the sets A and B."
    That help at all? My only knowledge of one-to-one is from matrices, but this looks a bit different.
    Mar 2005
    NY
    Quote Originally Posted by Cheekz185 View Post
    a. {a , e, i, o, u}
    b. {5, 10, 15, ...}
    answers to be:
    2, 4, 6,...
    7, 14, 21....
    set b is multiples of 5
    the first set of answers is multples of 2.
    the second set is multiples of 7.
    but her'e the rub, if you add the first set of answers to set b, you get the second set of answers. lol tha'ts me over thinking though.
    My best guess is that they're multiples. I think a,e,i, o,u...Are you sure its just not a bunch of variables? I mean, it says the FOLLOWING SETS, not each set. i think you have to treat them together. They must be variables
    Carputer Progress: Here we go again...
    THE GF THEME
    Genesis has speed
    Genesis has class
    Genesis sent money
    before your a__;)
    Join the fight against carputters. EMAIL ME!
    FLAC ShawJohn's Avatar
    Aug 2004
    On the edge!
    whats this for then Steve?
    Variable Bitrate Nerd2's Avatar
    Dec 2006
    Bristol/Cambridge, England
    Wierd questions. What's the context? What level maths is this supposed to be? Any 5-element set could be put in 1-1 correspondence with a,e,i,o,u
    Constant Bitrate mwmcginn's Avatar
    Dec 2006
    St Louis
    couldnt that be any set of non vowels in acending order at the same interval?
    bfjpv
    Mike M
    2006 Accord VP Sedan
    My worklog
    http://www.mp3car.com/vbulletin/work...-dads-car.html
    Dec 2006
    If this is actually a maths question, then it has nothing to do with the fact they're vowels, or letters in fact.
    {a,e,i,o,u} can be put in one-to-one correspondance with {b,f,g,h,p}, or {elephants,apples,pigs,fords,bananas} or even {,$,%,^,&}.
    saying two sets can be put in 1-1 correspondance is just saying, I can pair up every element from one set with an element in another set. And every element from one set has a unique pair in the other set.
    b) is there to show you an example of 1-1 correspondence with infinite sets. So, sort-of counter-intuitively, {1,2,3,4,5,..} would be a correct answer, as it is in 1-1 correspondence with {5,10,15,20,25,...}.
    Dec 2006
    St Louis
    Well, I am no mathamajician. Just trying to logic out a pattern from the example.
    Mike M
    My worklog
  1. Lilliput TouchKit problem solved!
    By AAVfReaK in forum LCD/Display
    Last Post: 11-07-2010, 08:29 AM
  2. reconnected puter and now audio problem..
    By NYCdesignkid in forum Car Audio
    Last Post: 05-30-2006, 11:09 PM
  3. gps navilock and com problem
    By lele67 in forum GPS
    Last Post: 04-01-2006, 07:41 PM
  4. Problem with directshow filter and WMP
    By EricE in forum Software & Software Development
    Last Post: 03-01-2006, 10:38 AM
  5. Car Idle - power/amp problem?
    By TheFaze in forum Car Audio
    Last Post: 12-15-2005, 11:10 PM
