Results 1 to 5 of 5
Thread: Communication between two computers
    Jul 2000
    Israel
    I have two computers at home,each one has 56k modem.I was wondering if I can connect between them by telefone cable.Which program should I use? I'm running win98.
    Retired Admin Aaron Cake's Avatar
    Jan 2000
    London, Ontario, Canada
    It actually CAN be done with a device that emulates the central phone system. But that device is several hundred dollars to buy, and probably close to one hundred to build.
    So go to a computer store and get a pair of $20 EtherNet cards, or a $5 null-modem cable and then use Windows direct cable connection.
    Maximum Bitrate Skippman's Avatar
    Mar 2002
    St. Louis, MO
    If you've got an old copy of Pro-Comm Plus (Back in the BBS Days) you could use that.
    But Aarons right, buy the NIC's.
    Stereo:Alpine IVA-D900 Head Unit | Alpine PXA-H510 DSP | Boston Pro Component Speakers Upfront | Boston Rally Rear Speakers | 2 Polk 10" Subs in the Trunk | Phoenix Gold Ti900.7 Amp
    Aug 2002
    you could get a USB Network Cable, but I;ve only seen them for $50. Its cheaper to go with network cards and a cross over cable. If you shop around you could prolly find a network card for free after rebate.
    Constant Bitrate samael's Avatar
    May 2001
    new zealand
    if you have a double phone plug (e.g a plug that enables you to have two telephones in one wall socket) , then just plug both modems into it. set you computer to be a dail up server (if your using windows , just look it up in help) , then the other one just have it dail 1 number (my friend and i couldnt do it otherwise) , make sure its set to not wait for the dial tone. but network cards are probably a better option , but its good to know these things in case your in a bind. you could also buy a null modem cable (i think ) , or usb networks are another option.
    stupid quote # 1 : "i dont do drugs , i only ever smoke pot when i'm coming down" , Me , 6 september , 2001.
