Results 1 to 8 of 8
Thread: Unrelated Car Mods
    May 2007
    Unrelated Car Mods
    Can anyone point me in the right direction for the following car mods that are loosely related to carmp3?
    1. Installing a mini-fridge that chills sodas and snacks while your car is running (perhaps even when the car is off?)
    2. Installing custom lighting in the interior of the car?
    Things of this nature.
    Thanks!
    Feb 2007
    Pittsburgh
    I can only see a mini-fridge being practical if you're going on a long road trip. The fridge needs enough time to cool down, and you cant have it on when the car is off, that will kill the battery so fast.
    I have custom lighting in my car. I have six blue cold cathode tubes (3 sets, 2 tubes and 1 transformer in a set) in my car, two under the dash, and two under each front seat. They're wired into mky parking light circuit so when I turn on my lights the tubes come on. I can draw you some schematics if you need them.
    May 2007
    That makes sense.
    That'd be way awesome of you. Thanks. Perhaps you have pictures of your completed project too?
    Variable Bitrate tigergibb's Avatar
    Nov 2006
    Snellville, GA
    and im sure the mini fridge would suck up gas
    2003 Nissan Xterra Worklog
    Total amount spent so far: $1196.64
    You will probably spend AT LEAST 2x what you initially budget for your CarPC Project!
    2003 Nissan Xterra - Modifications
    _
    Mar 2004
    Little Elm, Texas
    thread moved to OT since it has nothing to do with installing a CarPC.
    Jan Bennett
    Variable Bitrate will1384's Avatar
    Feb 2005
    Jefferson, AR U.S.A
    they used to sell an arm rest / cup holder with a soda cooler in it
    ran on 12v, but from what I remember it was for trucks and was big
    found some thing almost like it on amazon
    and another one
    I have also herd some cars use air from the AC unit to cool drinks
    Mar 2006
    Colorado, but Canadian!
    There some new domestic thing with chilled cupholders too. And it cant be that big because it is a car.
    1.9in x 2.9in -- 47mm x 73mm
    Maximum Bitrate eugenen's Avatar
    May 2002
    Ohio
    There are plenty of peltier based "refrigerators" that you can buy cheap. I run one from my secondary battery so I don't run down the starting battery.
  1. FAQ: Why not Home PC speakers for the car?
    By RedGTiVR6 in forum The FAQ Emporium
    Last Post: 03-08-2010, 09:44 PM
  2. What's your dream car?
    By Aaron Cake in forum Off Topic
    Last Post: 10-02-2007, 08:34 AM
  3. Replies: 9
    Last Post: 06-08-2006, 06:15 PM
  4. Employee Discounted Cars: Flatout BIG LIE!
    By sdashiki in forum Off Topic
    Last Post: 10-31-2005, 06:53 PM
  5. Car PC EZ 2.4 SDC/Inverter Controller - NOW Avail!
    By hd54321 in forum Power Supplies
    Last Post: 02-24-2005, 01:42 PM
