Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 37
Thread: Sludge in Engine
  1. #11
    Mar 2007
    columbus
    Plus Customer service said that the dealer should've noticed sludge comming out of the engine in the other services whereas Frankston are saying you can't detect sludge from just draining the oil.
    they knew about the problem and didn't want to alert you to it hoping that they wouldn't be eating the price of replacing their faulty engine.
    i have read the TSBs here in america about this problem, once a few years ago on a 1MZFE engine i had to use compressed air to force the sludged oil out of this guys car. now mind you we serviced his car regularly. toyota claimed that he didn't change the oil enough, if i remember correctly they stated 7500 miles. anyway this guy came back and i printed out all of his service records from our shop. after some *****ing and moaning toyo replaced his engine. so i would press the issue with your dealer as far as the law will allow until you are taken care of.
  2. #12
    Variable Bitrate Fox_Mulder's Avatar
    Melbourne, Australia The Truth Is Out There
    Now Toyota are offering $5,800 which I will accept we need a car and on the condition that I withold my right to take the Toyota Motor Corporation to court and sue for negligence in maintaining my engine.
    Consumer Affairs have decided to help me out and are getting the VACC (Victorian Automotive consortium place thingy) to conduct an analysis on the engine. The VACC are saying that they think it's cos Toyota Frankston used the wrong oil or engine cleaner or didn't change the oil in the car, well well soon find out with the analysis done.
    Consumer affairs will then take our case to Court against Toyota Frankston and Toyota Motor Corporation Australia.
    Fox Mulder
    2001 Toyota Avalon Vxi
    Toshiba TE2000 Laptop 1Ghz BU-353 Black Xenarc 700TSV HD & Analogue TV FM DVD/CDRW Car2PC Adaptor
    2004 Toyota MR2
    Intel Dual Core 2.0Ghz 1Gb DDR2 160GB SATA2 M4ATX Lilliput 7" TS BU353 DiNovo Mini Car2PC ODBII
  3. #13
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Glad that consummer affairs getting involved. Let see what coming out of this case.
    You know, it's really suck to get Toyota to admit any wrong doing giving that they have a good history of reliable cars. Their newer car starting to have problem here and there. A simple case is the Mk3 Supra 7M engine with BHG. They never admit that the gasket design and head bolts they use wasn't strong enought for the engine. They all blame the mod to the engine that cause the problem. Feaking, I don't have any mod on the engine other than a dropin K&N filter. I still have BHG at 95Kmiles when I bought the car at 68kmiles . Previous owner had all services done by a single dealer where he bought the car. Other peole mod their engine also had BHG at about the same milleage. That was for the turbo engine. NA engine also fail but all within 10-20K miles later than the turbo. When people crying out about faulty head gasket and bolts, they start changing the design. If it isnt' a problem, why they changing the design?
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  4. #14
    FLAC muldrick's Avatar
    Jun 2004
    South-Central PA
    My 2 cents:
    I worked at a Lexus dealer for 5 years, and now at a Toyota dealer.
    A dealer would be unable to tell whether the engine is sludged while doing an oil change. They pull the drain plug and remove the filter, they only see dirty (or very dirty) oil coming out. The sludge part stays in the engine.
    I've never heard of any dealer (or any shop for that matter) suck the oil out through the dipstick tube...that's nonsense, and actually be more time consuming.
    For several years Toyota "readily" did the repairs on these engines, they even sent out notices to owners notifying them to have their cars checked. (One valve cover has to be removed to properly check it)
    In the last 2 years or so Toyota has slowly "done away" with free repairs.
    About the PCV valve (Positive Crankcase Ventilation): changing the PCV valve won't do anything. When repairs are done (or with a new engine), the engine gets new (revised) valve covers that have better "crankcase breathing abilities" thereby reducing sludge (or gell) build up.
    I feel the problem is/was two-fold: lack of proper oil changes (I've seen 100's of engines that where fine when the service intervals where done within 5000 miles)
    The valve cover design was an issue, but the bottom line is that oil changes must be done every 5000 miles, and oil sludge most likely will not occur.
    I think Toyota has been quite generous in doing these repairs. At my dealer people came in with proof of only 1 oil change per year, and the repair was done for free. Once per year???? or 12,000 miles??? that's rediculous.
    CHANGE YOUR FREAKING OIL PEOPLE!!!!
    AtmosUSA.biz, E-Cig Mods
    "A great smoking alternative"
  5. #15
    Maximum Bitrate v8 scimitar's Avatar
    Jan 2005
    Scotland
    so your saying that pulling the dipstick putting a tube down and switching on a pump is more time consuming that raising a car, removing all the undertray stuff which often involves removing the wheels then undoing the sump plug and all the other stuff??
    I think if its an absolute must that you change your oil at 5000 miles in an everyday road car Toyota are going to loose market share big time. 12500 miles is the norm on most cars for about the last three years in Europe. It makes environmental and financial sense and reduces the cost of ownership. 5000 miles is a total joke and if they cant do better than that they deserve to go out of business.
    Visit my site V8 Scimitar
    SP13000, 300GB SATA HD, 1GB DDR. Opus 150, K301 screen, Cisco WIFI, AQmax GPS, RoadRunner and FreeDrive, Sony MEX-R5 head unit. 4 years installed and it just keeps running!
  6. #16
    Mar 2006
    Colorado, but Canadian!
    Even in our lexus manual it tells us to change every 8000 miles. Jiffy Lube and such will tell you 3000. They make that synthetic oil that will supposedly go 15000.
    8000 to 10000 miles is about normal in most other countries. They just try to rip you off here. Obviously a cheapo US domestic might need that 3000 mile change though.
    1.9in x 2.9in -- 47mm x 73mm
  7. #17
    Jun 2004
    South-Central PA
    Quote Originally Posted by v8 scimitar View Post
    so your saying that pulling the dipstick putting a tube down and switching on a pump is more time consuming that raising a car, removing all the undertray stuff which often involves removing the wheels then undoing the sump plug and all the other stuff?? .
    Yes...it takes time to "suck" oil out. Besides, on most Toyotas you have to remove nothing to get to the drain plug and oil filter...certainly not wheels. I don't know of ANY car that involves removing wheels to do an oil change. Sorry Sir, and I do not intend to offend you, but you have no clue as to what you are talking about, leave it to the techs, and I won't pretend to know what I am talking about when it comes to your trade.
    Then again, maybe they just do oil changes funny like that in Scotland.
    That is the Toyota recommended service interval in the US...don't know about the EU.
    I don't think that'll happen anytime soon.
    Like I said, there was/is a valve cover issue to blame, but that is not the only blame.
  8. #18
    Jan 2005
    Scotland
    No offence taken but I know who doesn't know what they are talking about and it isn't me.
    Fox I really hope you get it sorted out and stick it to them. I am out of here before anymore jerk racist remarks are made from people who haven't a clue.
  9. #19
    Jun 2004
    South-Central PA
    Dang, thanks for the tip. 25 years turning wrenches, and I've been changing the oil wrong all this time.
    Whaaa???? Racist?????
  10. #20
    Takes it in the Rear kevinlekiller's Avatar
    Dec 1969
    Where the penguins and polar bears live.
    Quote Originally Posted by muldrick View Post
    I stand behind Muldrick , every car I have changed oil is just a bolt on the oil pan , and most cars was direct access , rarely a plastic was over, and most of the time if there was , there was a hole to put the ratchet in.
  1. Engine Noise due to ground loop or amp?
    By matt11601 in forum Car Audio
    Last Post: 08-26-2009, 09:38 PM
  2. Replies: 23
    Last Post: 03-01-2007, 05:37 PM
  3. Shutdown media engine
    By supergeek in forum Media Engine
    Last Post: 08-11-2006, 10:18 AM
  4. engine wine know how its there but can't get rid of
    By michaelrj9 in forum Car Audio
    Last Post: 11-05-2005, 09:58 AM
  5. Noob Questions: Turning Off Media Engine
    By FiReToY in forum Media Engine
    Last Post: 01-01-2005, 08:36 AM
