Results 1 to 5 of 5
Thread: Air Condition Problem
    May 2007
    Dear experts,
    I have a 96 Honda Civic.
    Recently, I replaced my Upstream Oxygen Sensor, in order to reach it, I tried to move the radiator. I unscrew one screw on the radiator, then I heard air releasing sound.
    When I was done with the oxygen sensor, I realized my A/C was gone.
    I went to the store and bought a recharging kit. But A/C is still not functioning right, I don't feel the difference.
    I really need your help.
    Thank you so much.
    Teng
    Oct 2004
    NY
    to recharge the ac the right way, it needs to be vacumed first & then charged with the correct amount of freon, those little kits they sell can be ok if your system is just a little low to give it a boost, but to fully charge an empty system you should take it to a shop with the correct equiptment for this really.., a car like that may take around 2 pounds of freon give or take, doing this with those tiny cans can cost as almost as much as having it done right & won't work as good either..
    Elsewhere
    Moved to Off Topic.
    How about the Wiki?
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Sounds like you created a leak, that will need to be fixed.... then recharge.
    TruckinMP3
    Read the FAQ!
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    Could be a leak, but he removed a cap. That shouldn't really cause it to depressurise though. Was it the low pressure or high pressure side? High is the insulated one. I think they both have valves.
  1. Xenarc Problem or Polarity Problem?
    By mbkowns in forum LCD/Display
    Last Post: 01-06-2007, 09:57 PM
  2. audio problem
    By tiburonputer in forum General Hardware Discussion
    Last Post: 08-11-2005, 04:58 PM
  3. YAOP (yet another Opus problem)
    By Frankino in forum Power Supplies
    Last Post: 06-19-2005, 12:17 PM
  4. Lilliput Powering On/Off problem
    By masch in forum LCD/Display
    Last Post: 05-09-2004, 12:55 PM
  5. power on problem ??? help please anyone
    By Pingo1969 in forum Power Supplies
    Last Post: 04-07-2004, 08:47 AM
