Results 1 to 4 of 4
Thread: slim rechargeable battery
    Apr 2001
    Madison, WI
    I have a zaurus SL-5500 and unfortunately there is no extrnal battery like pocket pc. So I'm thinking about make one myself.
    I was thinking about 4 or 8(parallel) NiMH AA batteries in a box , but I'm wondering if there is slim rechargeable battery ??
    Thanks for help
    Mar 2001
    Cincinnati, Ohio
    I know that for Laptops atleast, the voltage does not have to be exact, many say to use 18volts in, but I've used 12, and they work, you just need more amperage. I wouldn't go below 12 though, because its at that voltage alot of stuff runs.
    At Ratshack, you can buy a 9.6volt or 8.4volt RC car battery, that comes with a charger, for around 30$. It is flat, a little thinner than a deck of cards, and about the size of a PDA. They put out around 2.5 amps. It would be rather easy to make a small circuit to up the voltage and lower the amperage, to make its 12 volts, or really, whatever you want.
    Or you can be really cheap like me, and toss a 40$ 12volt gel cell in your bookbag and haul it around school to power your lapt. It'll run it for almost 8hours, but I only use it for about 3, then I hook it up to a car battery charger in a trickle charge as soon as I get home. Works like a charm, and I get to say I have my laptop connected to a bomb, when the stupider people ask me what the cord running into my bookbag is for ;-)
    Clarion 200watt head unit w/ Aux in.
    Kicker 800watt 4 channel amp
    In a 96 Grand Prix SE.
    Mar 2001
    Cincinnati, OH USA
    What do you mean by external battery? From what I have seen of the Zaurus SL-5500 it has a removable and rechargable battery.
    http://www.mp3car.com/usersites/Maveric/ M.A.V.I.C. System
    Asus MB, PII 266, 192 MB Ram, 6.8" LCD, 6 Disk CD-ROM, 21 Gig HD, All-in-Wonder Video w/ TV Tuner, Irman, Windows ME, Winamp, Cobra III -- All in a custom acrylic case.
    http://www.mp3car.com/usersites/listings/ MP3car Listings - Please add to it! :)
    Apr 2001
    Madison, WI
    yes, zaurus uses external battery but it only last about 1-2 hours , not to mension extra battery charger & battery cost over $60.
    on back of Zaurus , it says 3.7v for internal battery and 5.0v for AC adapter.
    I was thinking about having NIMH rechargeable battery pack(pack of 4 A batteries) from Digikey( each battery has 1.2v 2100mah) but it seems bulky to carry both zaurus and battery pack.
    So I was lookingfor slim rechargeable battery.
