acceleration wise you will not be able to tell much difference... As for rubbing, your overall diameter should not change if you size your tires properly, you will just use less rubber on the larger rims they will be effectively the same size... less sidewall (18" rims) will give you a stiffer ride but the sacrafice is you will feel every little bump that much more...
LinkBack URL
About LinkBacks
