Results 1 to 6 of 6
Thread: What homebrew PVR do you use?
    _
    Mar 2004
    Little Elm, Texas
    I know about MythTV, pcHDTV, Media Portal, and Freevo, but I'd just like to check my options out there. What do you use and what are your results?
    Jan Bennett
    Aug 2004
    at home
    Freevo : simple, efficient, lightweight compared to MythTV but has less options.
    MythTV: powerfull, heavy but nothing is missing in it.
    It depends on which machine you set them.
    Maximum Bitrate Megalomaniac's Avatar
    Jan 2006
    The Colony, TX
    ATI HDTV wonder
    Apr 2005
    Queens, New York
    Gb-pvr also Meedio...
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
    Variable Bitrate Zogg's Avatar
    Apr 2005
    Plano, TX
    BeyondTV with 2 HDHomeRun's for unencrypted QAM recording plus 2 Hauppauge PVR cards for DirecTV recording.
    Z
    Zotac N630I-D-E M/B w/ Nvidia 7100, E5300 cpu, Xenarc 700IDT, M2-ATX, XP, RR & DFX 5.1.
    Mar 2006
    Colorado, but Canadian!
    I had a MythTV box, but just upgraded to a satellite tuner with 100hr DVR built in. (No extra fee or anything). The thing is, MythTV recordings were unreliable because the satellite receivers we had and still have are only controllable via IR. So a IR transmitter next to the receiver is not very reliable. This means you record the times you want but the wrong channel!
    It had nothing to do with MythTV, but control of your cable/satellite box is key to a happy DVR. Other than that, I like'd its interface, but overall the all in one unit is much nicer. Although I cant customize it very much. Oh well.
    1.9in x 2.9in -- 47mm x 73mm
  1. PVR 150 Tv/FM and 1.6
    By ryan-neil in forum Centrafuse
    Last Post: 03-06-2006, 11:52 AM
  2. How do I use radiator with wintv pvr usb2
    By dnkyntz in forum General Hardware Discussion
    Last Post: 12-17-2005, 04:46 PM
  3. Replies: 2
    Last Post: 02-04-2005, 11:15 AM
  4. Replies: 10
    Last Post: 10-08-2004, 08:50 PM
  5. Hauppauge PVR USSB2 for TV/FM Radio
    By MikeH in forum General Hardware Discussion
    Last Post: 12-04-2003, 09:50 PM
