Results 1 to 8 of 8
Thread: Magical leprechans and Unicorns
    Raw Wave lostreception's Avatar
    NY
    I am a dj by hobby but my laptop sometimes bogs down when im using a piece of hardware called Serato Scratch Live which basically is an external device that listens to timecode fed into it and slows down speeds up and scratches a mp3 in realtime.
    the Serato box runs off of the USB bus. I have it plugged into my laptop and I also have a IDE to USB2.0 converter with all my songs on it. on occasion it will bog down and freeze up slightly which isnt good.
    So i was thinking of getting an NAS drive and running the mp3 hard drive off of that and leave the USB clear for only the Serato box. but I was looking at the specs on some of the NAS drives and they seem to have more thoroughput availible on USB. Im confused what to do cause NAS will offer 100MBps but USB offers 400MBps.
    Should I get the NAS enclosure or will my results likely be the same or should i transfer the ide music to a sata drive and run that in the NAS. or try Sata and USB? whats a better option without spending too much and getting the most bandwidth?
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    [(o)______(o)]b VanPimpin'
    LostReceptions Apps D/L Here
    GPSGasoline- Rewriting
    CarPCNetwork
    NY
    a little clarification on the title
    seriously does anyone know or have an idea?
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    CarPCNetwork
    If you have a gigabit ethernet port, use that! If not Firewire. Firewire seems best for heavy transfers of files!
    Bowel movement jjh221's Avatar
    Dec 2003
    not sure yet.
    definitely unicorns
    I GIVE FREE HUGS!
    Buy Sell or Trade
    If my pm box is full, please feel free to call me any time. 440-328-3382
    Thank you
    Forex
    Rate Mp3car @ FXroot.com
    cheap custom title JC-S60's Avatar
    Mar 2004
    Ghent - Belgium
    It depends how your software reads the mp3's. Ethernet is ok for throughput, but a nightmare for access times (protocol dependable).
    Maybe do a test with a bunch of mp3's on the internal disk, just to see if that solves the problem.
    If so, use firewire if available on your laptop, or a pcmcia card with usb2/firewire/sata, depending on what you have...
    Joachim
    NY
    jc the software has the whole mp3 available and cached once loaded in case i need to sample or scratch back to the beginning of the song
    even ram might help now that i think of it but it already has a gig and is a dual core
    so basically either way keeping both on usb is a bad idea right.
    im a newb with dual cores its amd i wonder if theres a setting in the bios or something hmm
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    CarPCNetwork
    Mar 2006
    Colorado, but Canadian!
    USB is very limited on bandwith, so your assumption of 1 on there is best. If you have the space for a PCMCIA card, Iwould get a firewire version. Seems like the simplest fix. Also make sure that dual core is running XP and not Vista. Vista bogs this stuff down, and its stupid security measures makes everything in general slower. So if you need speed...
    1.9in x 2.9in -- 47mm x 73mm
    NY
    then i guess comes the next logical question is pata/ide gonna outshine sata/serial by all that much in this application you think?
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    CarPCNetwork
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 11:30 PM
  2. Slim dvd drive problems. JAE 50pin to IDE at fault?
    By 2k1Toaster in forum General Hardware Discussion
    Last Post: 08-16-2007, 05:06 PM
  3. SDK commands over the serial port ????
    By tolisn in forum Road Runner
    Last Post: 12-14-2005, 01:03 PM
  4. Looking for USB2.0 -> IDE Circuitry
    By Fusion-One in forum Classified Archive
    Last Post: 08-09-2003, 11:58 PM
  5. Via Mini-ITX Epia 5000 serial port not working
    By vash in forum General Hardware Discussion
    Last Post: 08-13-2002, 09:48 PM
