Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
Thread: 30yr old Wooden Sliding Window Stuck closed
  1. #21
    Registered User
    May 2003
    Quote Originally Posted by Enforcer View Post
    How?
    Does it go out and get itself a job deliverying pizzas or something?
    ...or maybe whore itself out, pay the rent itself that way as well as enough to buy cracks
  2. #22
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    you could try replacing it with a Linux
    Do you think kde or gnome would be better for light transmission and openability?
  3. #23
    Maximum Bitrate TimmyM's Avatar
    Aug 2003
    Federal Way, WA
    take a flexible, not stiff putty knife, and slide it around the inside and outside between the window frame and the stop. check to make sure there is nothing holding it like a nail or screw. sometimes people will do that for security. from the outside you should be able to get a pry bar like a wonder bar under it and start to pry up. if it stops slide the putty knife around it again. once it's up some grease in the tracks will help a lot.
    supposely window replacement saves energy, therefor saves money. BUT in a house that old it might not even have insulation. That would be more of a savings then replacing windows. Specially in the ceiling. You can have it blown in or do it yourself. I believe Home Depot rents the blower and sells the insulation for it. Insulating the walls would require a professonal service.
  4. #24
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by TimmyM View Post
    Its a slide horizontal window, and as predicrted we got our snow today! 3" of fresh heavy packing snow over everything. Gave the window a good yank and out it came. I guess it had something to do with the weaher...
    And the house was a model home when they built this area. Only house on the block with all hardwood floors, all insulated, finished basement, air conditioning, ect...
    Thanks for the tips. I am going to go make a snow man!
    1.9in x 2.9in -- 47mm x 73mm
  5. #25
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by 2k1Toaster View Post
    You want to make someone who can drive a truck and talk on the CB to a guy driving a Pontiac Trans Am
  1. Onscreen keyboard
    By gti in forum Map Monkey
    Last Post: 06-14-2008, 10:00 PM
  2. Alpine City Cruise
    By Hell-Stopper in forum RR Skins
    Last Post: 02-22-2007, 10:05 PM
  3. iGuidance 2.x auto-run shortcut
    By ziggyrama in forum GPS
    Last Post: 08-13-2005, 06:05 PM
  4. How to embbed any Application in RR ?
    By guino in forum RR FAQ
    Last Post: 03-20-2005, 12:35 PM
