Results 1 to 10 of 19
Thread: Remote start on manual
    Variable Bitrate dhantiflag's Avatar
    Nov 2006
    Mentor, OHIO
    Ok, so i was looking around today thinking bout install remote start on my 08 SI, now i know there are things about installing on manual transmissions and such but i saw this today.
    DEI 689M Neutral Safety Module
    it came out in the US in like september? im not sure how it works or what not, but i really want remote start on my car because winters are very cold, and it will give the pc some time to boot up...
    any ideas?
    Nov 2006
    Mentor, OHIO
    remote start on manual
    Ok, so i wanna get a remote start installed on my 08 SI, its manual and i know with manuals that if you leave in gear, well its not pretty.
    but i was reading about this DEI 689M Neutral Safety Module and i was wondering how it works and what exactly it does and is it safe now to install on manual?
    Elsewhere
    Moved from mp3car.com store to Off Topic.
    Pay attention to where you post and quit crossposting.
    How about the Wiki?
    Nov 2006
    Mentor, OHIO
    well i created the 1, and then i went looking for it and couldnt find it so i thought my Internet died or something and it didnt post, sorry i must have missread i thought i read it was anything that was mp3car related so i figured remote start is close to a carpc...
    sorry for the problem, ill be more careful
    FLAC muldrick's Avatar
    Jun 2004
    South-Central PA
    If the remote start is specifically for a manual it'll be fine.
    Newer cars have gear position indicators on the tranny, even a manual. When you install the remote starter it will tie into this switch/device, and disable the remote starter if it sees that the car is in gear. Obviously it enables the remote start only if it is in neutral.
    BTW: I installed one on a truck I once had that did not have that indicator on the tranny. Yes, I left it in gear once, hit the remote start and (luckily) hit my daughters car in front. Had her car not been there it would've driven....who knows where...and killed who knows who. I learned my lesson on that one. DO NOT install a remote start unless it is designed specifically NOT to start if your car is in gear.
    AtmosUSA.biz, E-Cig Mods
    "A great smoking alternative"
    Newbie dizave's Avatar
    Nov 2007
    Indianapolis
    Remote Start for manuals
    Hello, I'm a newbie to car pc topics, but remote starts I do know well. You guys are making remote starts for manuals WAY too complicated. About 5 years ago, I put a remote start on my manual 98 Integra GSR. I found the product on eBay for 60 bucks. Just search Ultrastart. Any product number with an M at the end means it's made for manuals. They have great support for new installers as well. After making all the required connections, you're good to go. (For the Integra, I didn't need any bypass module or added security bypass relay) Here's the beauty of it. As I am pulling into a parking spot, of course I had my foot on the brake to stop the car - step 1. Step 2 - pull the e-brake. Most of do these steps naturally so it's not a hassle. Step 3 - turn "off" of the car and take out the keys. The engine keeps running! You MUST be in neutral for this to work otherwise you simply can't get out of the car! Next - get out and as soon as the door closes the engine shuts off and your car is ready to be remote started. It's THAT simple. :-)
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Tooo complicated.
    I Posted this before, but here we go again. I installed it in my Supra almost 10 years ago and I am still using it.
    - Use e-brake ground wire as the remote module ground wire => If brake isn't engage, no ground to the module, it won't work and can't start.
    - Put a Normally Close (NC) lever switch or 2 by the shifter and link it to the e-brake wire above => If the shifter is on up position (1st gear), that set the switch and disconnect the above wire. No ground to the remote starter module, it won't work.
    - Use a relay to by pass the clutch safety switch. Normally, most remote module has output signal during start and running. Use it to connect/disconnect (depend on car) the clutch safety switch.
    That's all it take, no other procedure/step needed to use it other than push the button to start. With in the past 10 years, I have no problem with the above method.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Nov 2007
    Indianapolis
    Remote start
    You must be joking! You think my method is too complicated, but your involves buying extra parts such as a NC lever switch (or 2) AND your adding a relay switch. ??? How can that possibly be any less complicated?? How much longer will it take to add this extra stuff?
    You take the ultrastart out of the box...you hook up the required wires. You're done. That's it. Not extra wiring...no extra purchases.
    I saw your original post. No need to post again, that's why I posted mine. ;-)
    The Dave
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    Quote Originally Posted by dizave View Post
    umm, I think matrix way is more simple, less steps and more fool proof.
    your car won't start if you forgot it in 1st.
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
    inh
    inh is offline
    Jan 2007
    Fort Riley KS
    I just dont leave it in gear and dont let anyone else drive, problem solved =p
    But on my next install in my new car, i'll be wiring up a neutral safety switch
    cashtexts - Earn money for receiving text messaged offers
    cashtexts review not a scam
    Space Navigator - 6 Axis input device: Take it apart - Driver App
    RRCam - Video/webcam capture, text overlay, and recording: 2.0 Stable
  1. Replies: 7
    Last Post: 12-14-2009, 09:34 AM
  2. remote start works but for only 5 sec
    By pech445 in forum Car Audio
    Last Post: 10-06-2005, 02:36 AM
  3. Installing an alarm with remote start
    By cheerio in forum Newbie
    Last Post: 02-07-2005, 11:28 PM
  4. PC remote start - via remote on your key
    By SAScooby in forum Power Supplies
    Last Post: 04-15-2004, 01:33 AM
  5. Automotive Security
    By Maeveth in forum General MP3Car Discussion
    Last Post: 04-07-2004, 02:33 AM
