Results 1 to 10 of 12
Thread: Check Engine Light Code
    Nov 2007
    I have a 98 Honda Civic DX, and my check engine light went off after I filled my gas tank. Went to mechanic, he said my code was PO135 bank 1 sensor 1. He says for me to change the 02 sensor. Just wanted to know is this emergent to do?
    _
    Mar 2004
    Little Elm, Texas
    thread moved to OT....not sure what in the world this has to do with CarPCs...or car audio for that matter...
    Jan Bennett
    Nov 2007
    Hey, I accidently posted in the wrong section, okay? No biggie...
    FLAC muldrick's Avatar
    Jun 2004
    South-Central PA
    No, no rush.
    AtmosUSA.biz, E-Cig Mods
    "A great smoking alternative"
    Nov 2007
    uhhh, you didn't tell me much of anything...
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    Any time you get codes like sensors, clear it, start the car, drive around the block, shut it off, then start it and drive again. If no codes, it was just a glitch. That might save you some $$.
    Mar 2006
    Montreal
    No offense, if you brought it to a mechanic to get the error code looked at, you should have got it repaired at same time, a sensor is easy to replace, it should be on the exhaust manifold in front of the engine of the civic.
    My 2000 civic had same problem, just a sensor to replace.
    Tony
    Nov 2007
    I know it's easy to replace. Couldn't get it repaired at that time, no dinero. But does it affect the performance of the car?
    Mar 2006
    Colorado, but Canadian!
    eventually it may screw up something depedning on how ECU dependant the car is. Bad readings so it makes bad decisions leading to bad engine.
    But for someone who not only posted in the wrong section, but the wrong bloody forum you really need to tone down the attitude.
    1.9in x 2.9in -- 47mm x 73mm
    Oct 2006
    Las Vegas
    Reset the PCM, if it doesn't come back you will be fine. If it does disconnect the sensor and take a resistance reading between the two black wires on the sensor's terminal connector (the two opposite the tabs) should be 10-40 ohms.
  1. FAQ: LCD Technologies
    By dontpntpool in forum LCD/Display
    Last Post: 03-15-2007, 01:20 AM
  2. Replies: 22
    Last Post: 01-05-2006, 09:26 PM
  3. Adding text-to-speech functionality to Media Engine
    By skippy76 in forum Media Engine
    Last Post: 04-19-2004, 02:38 AM
  4. Adding file syncronisation to Media Engine
    Last Post: 03-27-2004, 12:01 AM
  5. PC tied into Engine Computer > Check it
    By AshsZ in forum General Hardware Discussion
    Last Post: 01-06-2003, 08:47 PM
