Results 1 to 9 of 9
Thread: windows 98 boot cd (not diskette)
    Sep 2002
    Washington, USA
    ever since I got into the whole MP3 thing I have formatted and messed with the partitions on my few hard drives quite a bit... the process is a life draining suckubus like process that will probably end up killing me.....
    You guys know how you can boot off the windows 98 second edition cd rom.... I want to make a bootdisk of my own that boots like that... I want to put all my 98lite setup files on it and a few programs.... I have been looking at nero's boot cd option but i really dont know where to begin because there is very little to almost no documentation on it.... I'm not sure what I Can and Cant do.... can you guys/gals help me out?
    Hardware: Via Epia, SB Live 5.1, Travelstar 40gig laptop HD, keyboard card, IR2PC module, Opus PSU
    Equipment: 600watt jensen amp, 4 x 6&1/2 3-way 200watt pioneer speakers
    Software: Win98Micro, Winamp, No DVD, Divx, or GPS yet
    Sep 2002
    Washington, USA
    after doing more searching i found a program that might help me
    "Does WinISO support bootable CD?"
    Yes, WinISO supports bootable CDs perfectly. WinISO can not only could edit a CD image file without destroy its bootable information but can also add bootable information to a CD image file to make it bootable!
    thats from there web site... So I was wondering what you guys think this mean... does this means i can take a bunch of files that i want to throw on a cd turn them into an image file and then make that image file bootable? only thing im wondering about that is will I have cd rom drivers loaded this way... cause ill need em to use the cd rom
    Variable Bitrate Stine161's Avatar
    Apr 2002
    Alberta Canada
    yo could also maybe add files to the 98 CD rom? then be sue to burn it to bootable again then you would not have to mess with all the boot headers and such just an idea
    Aug 2002
    longview washington
    easiest way i have found to make boot cd that i use to repair puters is to have windows make a boot floppy then use nero burning rom there is a option to make a bootable in the are where you choose what kinda disc you want to make if you read the screens you ca figure out what it needs as it pulls the boot info from the flopy and puts it on the disc also you can add files to the cd as well like 98 and whatever else
    hope that helps some
    WINNER!!!!
    run-on sentance comp 2002!!
    FLAC MP3DUB's Avatar
    Jan 2002
    Chicagoland, IL
    EasyCD creator does the same thing. For my job I've created some custom floppy boot disks for ghosting from either the cdrom or a network source automatically, and I just had to tell easycd to make the cd bootable from the floppy.
    -Nick
    _____________________________
    Monthly MP3Car Chicago Meets
    www.mp3vw.com Last updated: 07/07/2008
    Jul 2000
    Ottawa, Canada
    I've done a few like this for installng win98lite i used nero w/o problems
    CD-Rom (boot)
    Boot Image using A:\ and put a windows recover disk in
    ISO settings for Dos compatability
    Drop the 98lite directy in
    Drop the windows cab directory in.
    [SIZE=1]'91 Nissan Stanza
    [XXXXXXXXXXXXXXXXXXXX] XX% Completed -
    Car Totaled and i bought a 20G mp3 player
    http://machs-fuel.tk
    a DIY video projector page
    Sep 2002
    Washington, USA
    hey Machs_FueL
    what size hard drive you got because whenever i try to partition or format my hard drive from dos I cant get passed the 8 gig limit for my 30 gig hard drive. I read somewhere that you have to be in fat32.
    Does anyone know of a program that can be used after booting with the 98 recovery disk to partition or format in FAT32 to take advantage of the additional disk space?
    Thank you soooo much to any that can help
    Jake
    Jul 2000
    Ottawa, Canada
    In the car i've only got a three, so i never had the problem...
    the MS site might be of help though
    Jan 2002
    Chicagoland, IL
    2.1gb is the fat16 limit. 8gb was a hardware limit back in the p1/early2 days. Theres no easy work around. The drive manufacturers had ways of making it work, or adding a pci ide controller.
    -Nick
