Results 1 to 7 of 7
Thread: Glass
    Jul 2005
    Glass
    how in the world do you remove the glass from car door?
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by TREYR View Post
    You mean like it got shattered and the pieces are rattling aroung inside?
    If so, then you have to take all the panels off and start picking out the glass. Could use a vaccuum I suppose, but I wouldnt trust glass shards being whipped into a cloth dust baggie.
    1.9in x 2.9in -- 47mm x 73mm
    Jul 2005
    Nah the glass is still all together i just need to trade it out for another one
    Variable Bitrate will1384's Avatar
    Feb 2005
    Jefferson, AR U.S.A
    use a shop vac - and goggles
    The glass in most cars is safety glass, that shatters into small square shapes, or cubes
    there is some tiny almost microscopic glass shards - but nothing major
    - if you mean to remove a sheet of glass - sometimes its glued to a metal track that
    pushes the window up and pulls it down, sometimes that track can be removed
    glass and all
    Jan 2007
    East Central FLA
    It will vary from car to car, but basically:
    take off the door panel
    Remove glass from whatever track mechanism makes it go up/down (sometimes there are metal stop strips & the glass may be held in with some through bolts)
    remove weather strip(s) at top of door frame
    lift glass out
    Now if this is a sedan (which I have never done), there has to be a big enough opening in the inner door's metal skin through which the glass can be passed - same principle, just comes out the bottom instead of the top.
    Jul 2005
    I took every bolt out i could find that was left and the window fell down like an inch but there is the track thing that runs all they way down the the door abuot 4 inches wide and if you move it the window moves but it can only go down an inch and then tahts the bottom of the door
    (95 honda passport)
    Maximum Bitrate redls1bird's Avatar
    Feb 2006
    Atlanta Ga.
    What door are you working on? If its a front door, sometimes you have to rotate the glass, so that the slant, or curve, tips downward, and the widest part comes up, and ultimately out of the door. If your working on the back, it can be decidedly more tricky, since they are basicly square. You may have to remove the guide strips that the window rides in to have enough clearance to get it out. This is purely speculation though. Good luck.
    Car Pc progress meter:
    [-5%-------------------] Carpc build #2. So far, 20$ deep! I love recycling!
    "The car is the closest we will ever come to creating something that is truly alive" -Sir William Lyons
    My worklog
  1. Need Replacement 8in LCD Glass, universal?
    By Nexson in forum LCD/Display
    Last Post: 04-01-2009, 03:03 PM
  2. Using Tempered Glass Instead of Plexiglass?
    By AznArkitekt in forum Fabrication
    Last Post: 10-14-2007, 10:53 AM
  3. how to fix broken LCD rear view mirror glass
    By yoyoshopping in forum Newbie
    Last Post: 09-17-2005, 01:09 PM
  4. extra buttons? IR glass? HELP
    By xdjxklusivex in forum Fabrication
    Last Post: 02-01-2005, 12:30 PM
  5. To Glass or not to glass that is my question
    By belezeebub in forum Fabrication
    Last Post: 11-23-2004, 06:46 PM
