make sure in this "kit" that smaller things like exhaust manifold gaskets valvecover gaskets thermostat gasket are in there
chilton or haynes books or bolth
you will need a torque wrench
permatex blue rtv form a gasket
penetrating oil<depends on how stubborn the exhaust nuts are>
antiseize lubricant is a good idea on the exhaust studs
before dissassemplby and before reassembly
also good 4 spark plugs and stuff
ops almost 4 got should you need to remove the exhaust maniflg from the car compleatly to do this don't ferget the donut gasket between the collector and the rest of the exhaust pipe <the books will show more >
oh yeah since you will betaking the intack manifold off make sure the intake gaskets are there i have picked up many different kits for diff engines and by diff manufacturors and they almost all do not include one gasket or another
you could look in a jegs or summit racing catalog for gasket kids in your year anf c.i.d of motor might save a few or go look at the recent website i ran across
http://www.expressautoparts.com/
i have yet to buy from them but the prices seem good
and no just cause a head gasket let go doesn not mean the whole motor is crap now
that all depends on if water got in the oil <pull the stick it wil look like milk almost if it did>
that dependng on how long it was drivin like that could just be as simple as a few oild changes to flush it out
another factor is did it overheat? if so how bad and for how long
when you go to put the intake back on at the front and rear of the enne block there is a lip thats is supposed to have 1 rubber seal there
my self i toss em in the garbage and make about a 1/4 or bigger bead of blue silicon rtv form a gasket <your application may need more or less> in place of the rubber ones it just helps save some headache at least for me to do that instead of the ruber strips that seem to have a tendancy to either leak oil or blow out sometimes
also on the actual intake manifold gaskets locate the ports for the water passages and put a little tiny smear of same rtv around just the water passages not too much or it will squish out and u get rtv bits in the engine or cooling system
if you pull the distributor cap off mark on the manifold where the rotor is pointing and make a match mark on the distributor caseing and the inatake manifold now as long as you do not rotate the motor while your doing all this work you should be able to just drop the dist back in to the same or close to same timing it had when it was runing then you can reset the timming when its all running again
oh yeah spray some penetrating ol like aerokroil or some other known good stuff on the exhaust manifold bolts and go have a beer <or pop your preference> whilst you wait for it to creep in
hope some of this helps
btw
what makes you say head gasket?
LinkBack URL
About LinkBacks
