Results 1 to 3 of 3
Thread: diagnose this
    Mar 2008
    diagnose this
    I have an older Gmc van 1989 3500 with a 5.7 engine automatic trans
    we get the error code 42, four flashes then two flashes. the books I have describe this but do not say how to correct th problem.
    very poor gas millage and throttle response.
    While setting the timing at zero degrees with the wire disconnected from the distributor. at reconnection of this wire the computer retards the timing up to 20 degrees.
    Thanks for your help Jay
    Elsewhere
    Moved to off topic.
    Understand that these foprums are focussed on vehicle PCs. Most of us aren't mechanics that can troubleshoot engine trouble codes.
    How about the Wiki?
    Maximum Bitrate fixerofallthing's Avatar
    May 2005
    Lawrenceville GA
    Tests/Procedures:
    1. Disconnect the set timing connector or ground the Tan/Black bypass wire.
    2. The check engine light should come on and code 42 should set.
    3. If the engine stops stalling, disconnect the pick up coil connector at the Ignition Control Module (ICM).
    4. Check acv output from the pick up coil while cranking the engine at a normal cranking speed.
    5. If output is less than 700 mv replace the distributor shaft with a new one.
    6. If the engine still stalls with the bypass open or shorted to ground see if adding alternative fuel to the throttle body helps.
    7. Wet down the coil and coil wire with water and see if the stall is induced at a higher RPM.
    8. Check for a loss of injector pulse or spark.
    Potential Causes:
    Distributor shaft
    Coil
    Coil wire
    ** Confirmed Fix **
    Distributor
    The Car 2005 Scion xB
    The Truck 2004 GMC Canyon
  1. OBD-II for BR-3 ActiveX (and code)
    By maxer6 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 06-23-2007, 03:46 PM
  2. help needed to diagnose touchscreen problem
    By don.davis in forum LCD/Display
    Last Post: 02-22-2007, 07:30 PM
  3. Inverter - PSU fault (diagnose = how?)
    By Samirnoff! in forum Power Supplies
    Last Post: 06-08-2006, 07:20 PM
  4. Problem building a new computer... can you help diagnose?
    By azzurro in forum General Hardware Discussion
    Last Post: 12-23-2005, 09:58 AM
  5. help diagnose dvd drive problem
    By tsai in forum General Hardware Discussion
    Last Post: 03-06-2005, 10:34 PM
