Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Dual Zone Microwave Sensor?
  1. #11
    Aug 2010
    did you read the manual for the sensor.
    The adjustment process should be.
    dip sw 1 on dip sw 2 off - adjust exterior sensitivity
    dtp sw 1 off dip 2 on - adjust interior sensitivity
    LED status indcation.
    solid green power on field setup (first 15 secs).
    solid yellow trigger output connected to 12V
    flashing yellow exterior LESS sensitive than exterior.
    flashing green exterior trigger.
    flashing red interior trigger.
    in running mode.
    both dip switches on - normal operation. (usually a short pulse on outer and long pulse on inner).
    both dip switches off - exterior output = 3sec pulse.
    If the alarm a some sort false alarm sensor detection this may need to be turned of to prevent the alarm from disabling the input as faulty.
    Finally if the sensor is sharing and input with another sensor each trigger needs to be diode isolated (Band away from alarm input to prevent interference between the sensors.
  2. #12
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    Been over 6 years since that last post you might not get a reply. But thanks for posting the info as it might help someone SNO
  1. New OBDII scantool - Beta testers?
    By tmort in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 11-16-2012, 01:35 PM
  2. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 10:30 PM
  3. Autopage 720 car alarm - trying to disable dual stage shock sensor
    By oldtima in forum General Hardware Discussion
    Last Post: 03-12-2008, 09:32 AM
  4. Dual Zone CarPC need advice
    By wicket in forum General Hardware Discussion
    Last Post: 10-20-2007, 02:26 AM
  5. dual zone prox sensor and wifi
    By sygad in forum Wireless Communications
    Last Post: 09-16-2004, 07:20 PM
