you would have to use RDP or VNC, or just SSH in your server then run the executable
I write installer applications (I can do some for RoadRunner and whatever if you want) and the installer creates registry values for various things like version numbers and ODBC information. I have a problem when I install the application from my machine onto a server, it creates the registry entries on my local machine. How do I change it so the registry values are created on the server?
The installer software I use is Inno Setup and I want to be able to install my application on a server via Explorer or simply a mapped drive.
Ampie Case
256 MB DDR2 PC5400
Xenarc 700TSV - VGA Monitor
Intel D945GCLF Motherboard
M2-ATX-HV
2005 Honda Civic
