Results 1 to 2 of 2
Thread: ActiveX Error In Unrelated Application
    May 2006
    Calgary, Alberta
    Unhappy ActiveX Error In Unrelated Application
    Guys, I have a question about a completely unrelated application I'm using. It was written by some guys in my development team and is written in VB.NET but calls another application which is written in VB6 I believe. When I try to use one of the functions, I get the following error:
    Code:
    Application Name: LINEMERGE
    Version: 5.8.1
    Module: frmMerge
    Procedure: MergeLines
    Procedure Step: DeleteLine.SeisLine; DELETE FROM SEIS_LINE WHERE (SEIS_LINE_ID LIKE '20202')
    Error Number: 429
    Error Source: LINE_MERGE
    Error Description: ActiveX component can't create object.
    Procedure State: Transaction has been rolled back - Database has not been updated.
    System Info: Windows Version = Windows 2000 (5.2.3790), Total Physical Memory = 767 MB, Available Physical Memory = 431 MB, Processor type = 586 (1 processor(s)), ERROR
    For this application to install correctly, there are quite a few .dll/.tpl/.ocx files that need to be registered using regsvr32 and even one that has to be done using regasm. Those were all successful and accounted for (except for one named SSPng2.dll which wouldn't register) and now I get this error. The application works fine on my machine which has had this application installed/uninstalled on it about 200 times for testing, but once I port it over to a virtual machine that I created with nothing on it, it won't work. I'm guessing there's some .dll file that didn't get registered or I missed (unlikely) but that's what Google searches are causing me to believe.
    The only other thing I noticed related to ActiveX is that I have a Microsoft.ActiveXPlugin entry in the registry of my machine but not in the registry of the virtual machine. Do I have to install the plugin? Where do I get it? All the ones I see online are for browsers, this is a desktop application.
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
    May 2006
    Calgary, Alberta
    Got a little ahead of myself, problem solved. I wasn't copying the .dll file that I had to register with regasm. Carry on.
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
  1. Masquerading skinned application
    By rodweb in forum RR Plugins
    Last Post: 08-06-2008, 09:12 PM
  2. Replies: 0
    Last Post: 09-23-2006, 09:38 PM
  3. How to embbed any Application in RR ?
    By guino in forum RR FAQ
    Last Post: 03-20-2005, 01:35 PM
  4. Bug Reports 1.09
    By frodobaggins in forum FrodoPlayer
    Last Post: 10-22-2004, 11:24 PM
  5. Bug Reports
    Last Post: 10-16-2004, 01:25 AM
