Results 1 to 6 of 6
Thread: Help hard resetting a 2Wire wireless gateway...
    The Lavender Tie Just
    Made It Obvious
    Rafster's Avatar
    Aug 2003
    San Diego, CA
    Hey guys,
    I'm trying to help my friend out. He got himself locked out of his wifi connection. He has ATT dsl and is using one of those 2wire Wireless gateway modems.
    He doesn't even remember the password to get in to the setup page.
    I've looked all over 2Wire's site and found nothing on how to do a hard reset, looked on Google, and well, call Att (but we all know how great Att is for support.... )
    Anyways, the only thing that I found, was pressing the reset button in the back for about 15sec. It didn't work.
    Does anyone know an actual way to just reset everything to factory?
    I know all the pppoe settings and stuff, just don't have the passwords to get in and help him get his wifi connection back.
    Thanks,
    Rafster
    Mar 2006
    Colorado, but Canadian!
    Reset is what to do.
    Remove power, and push the reset button down for up to a minute. Some routers need 30s to restore to defaults, so maybe this needs a while too.
    If you leave power in, it might only do a soft reset.
    1.9in x 2.9in -- 47mm x 73mm
    Oct 2008
    The router is supposed to be plugged in while resetting. Press and hold the reset button for about 12seconds. Some routers take up to 30secs. You can also check here http://support.2wire.com/index.php?p...ord&cat=&sort=
    Mar 2006
    Quote Originally Posted by f1ip View Post
    Most are not to be plugged in to guarentee a reset.
    Oct 2008
    not so for my Linksys and netgear. so do the Westells that VZ uses. (Did tech support for VZDSL for a while) So do Dlink's. haven't seen routers that will reset while powered off. I dont use 2wire since i dont use ATT DSL. But i've always assumed to do the same thing as other routers i've encoutnered with.
    Made It Obvious
    Rafster's Avatar
    Aug 2003
    San Diego, CA
    Got it working! Thanks!
    Rafster
  1. Hard Drive Issues in a Vehicle Computer
    By DarquePervert in forum The FAQ Emporium
    Last Post: 02-23-2008, 01:35 PM
  2. Boot from a external usb hard drive?
    By DjChrishim in forum Newbie
    Last Post: 12-04-2007, 08:47 AM
  3. Hard drive shock / vibration thoughts
    By S11D336B in forum General Hardware Discussion
    Last Post: 09-26-2006, 11:40 PM
  4. carputer hard drive died in 3 days
    By therussman2002 in forum General Hardware Discussion
    Last Post: 08-10-2004, 01:49 PM
  5. I found wireless Cards (15 buxs) and gateway (65 buxs) for cheap!
    By crazyshaxs in forum General Hardware Discussion
    Last Post: 02-07-2002, 08:18 PM
