Results 11 to 20 of 22
Thread: Burning Windows 7
  1. #11
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Quote Originally Posted by dMand View Post
    If you can't get it to go on a DVD, but do have a large enough thumb drive, you can follow the instruction guide here:
    http://www.maximumpc.com/article/how...beta_a_usb_key
    I've tried it, and it works!
    Looks like it can't be done from XP, is that true?
  2. #12
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Quote Originally Posted by treetop777 View Post
    You can not upgrade from XP to W7. You can only upgrade from Vista to W7. W7 requires a clean install if you are using XP.
    1X Ainol Novo Flame Tab
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1X 7 inch motorized Screen
    1x Win 7 PC
  3. #13
    One Sharp Cheddar ThunderStick's Avatar
    Aug 2006
    West Allis, WI
    use a DVD-R instead of a DVD+R
    This is what nero required to burn it...
    New Age Garmin - Skin for RR
  4. #14
    Sep 2006
    War-Town, GA.
    Quote Originally Posted by HiJackZX1 View Post
    Sorry, i didn't explain myself, what i was asking is it looks like (from the link) that to setup a thumb-drive to load W7, you have to do it from within Vista -setup the thumb drive that is!
  5. #15
    Variable Bitrate dMand's Avatar
    Oct 2007
    The Evergreen State, Washington
    HiJack is correct, upgrade is only available for Vista SP1 and later.
    Nevertheless, it's always best to get rid of the clutter and start off with a clean install for reliability.
  6. #16
    Sep 2006
    War-Town, GA.
    The link you posted is very good, thanks. It shows how to setup a thumb-drive to load W7 from it; in that how-to i saw this: "Note: This guide will only work within Windows Vista."
    What i understand by that is that it will be impossible to setup the thumb-drive unless it's done on a computer running vista - is that correct?
    You said you tried and it work; did you setup the thumb-drive on a vista computer?
  7. #17
    Newbie spdracr's Avatar
    Mar 2008
    i have used imageburn and it worked the first time
    i wouldnt install windows 7 over your current OS since its only a 4 months trial license
    you should make a partition on your HDD and install it on there and you will have the option to choose which windows you wanna boot when you turn on your computer, thats what i did
    http://i233.photobucket.com/albums/e...cr83/Mycar.jpg
    '00 Mitsubishi Galant ES 4g64
    '91 Volvo 740 Turbo B230FT
  8. #18
    Jul 2005
    My windows 7 download was 2.4 GB - I downloaded the complete new install version - maybe you'd have better luck with that.
  9. #19
    Low Bitrate Twinsen's Avatar
    Apr 2006
    Memphis, TN
    Quote Originally Posted by f1ip View Post
    try ImgBurn. it's FREEEEEEEEE. i've used it 100's of times.
    +1Million to IMG BURN
    God I love ImgBurn.
  10. #20
    Oct 2007
    Negative on the first question. No, I did it in XP.
    My thumb drive works to install Windows7, and will also install Windows XP from it.
    Look for a thumb drive boot program called "Komku-SP-usb" and work with it from within the command prompt. I loaded my SATA drivers on the thumb drive together with XP pro SP3 without a CDROM or floppy disk, and commenced to doing the installation. Komku is fantastic!
    http://komku.blogspot.com/2008/11/in...lash-disk.html
  1. New Frontend for Windows and Linux
    By gbr in forum Other Cool Front Ends
    Last Post: 01-21-2009, 09:55 PM
  2. Vista experiences anyone?
    By Nomader in forum Road Runner
    Last Post: 01-10-2008, 09:01 PM
  3. Installing Windows 2000 Pro on a 1GB Microdrive
    By JeremyM in forum WinNT Based
    Last Post: 05-07-2005, 10:56 PM
  4. Windows Freeze When Crank, Crank again windows unfreeze
    By antimatter in forum Power Supplies
    Last Post: 07-27-2004, 01:40 AM
  5. Windows ME and MediaCar
    By dug1967 in forum MediaCar
    Last Post: 04-15-2004, 02:30 PM
