You coudl use a 74LS193 combined with a 74LS138. Wire the "3" decoded output from the 74LS138 back to the master reset of the 74LS193. The system will then count 0, 1, 2, 0, 1, 2 over and over. Use 0, 1 outputs to drive your lamps.
When 2 is active, that will be the off stage. You can add lamps or change the sequence by moving the reset tap on the 74LS138.
You may need the non inverting output version of th 74LS138 (can't remember the exact part number atm).
Rob
LinkBack URL
About LinkBacks
