HiJackZX1 w/ The Tobiathin Core PC system!
ZOTAC GF9300-G-E
INTEL E8200
4 Gigs
OCZ Vertex 2 SSD
OPUS 320
1 Lilliput, 1 MTSVO-SC K301, 4 VM70 screens, 1 Eonon 19in
Starting Raspberry Pi multizone project.
Ban you for what? You've done nothing wrong. There are no rules against cruddy attitudes. Just as I have done nothing wrong.
1.9in x 2.9in -- 47mm x 73mm
I don't care. Someone else may ban you, but I won't reprimand for someone voicing an opinion.
i would never ban you either if I had the power. Its fun putting you in your place and making you look stupid. Its much better then coffee. This is bad though because he causes people to get so upset that we are filling peoples threads with $h!+. Let me get it back on topic:
CrimpDaddy: About fiberglassing, is it hard to get those shapes and stuff? Also do you know how to do textures? I have had Nexson do my dash bezel for me, and his work is awesome, but he cannot match the texture I have. It would be to much of a mission to sand all the texture off of every interior piece. So is there a way to match it the new fiber glass to the current texture? I do know that Dodge based the texture on vinyl, which is the pattern they use on all vinyl printing patterns. I was going to build a box out of wood, then wrapped in the vinyl and although the texture matches, it doesn't look right next to the plastic version, as in, you can tell one is soft and the other is hard. Same with the console, i have the original console, then I removed the middle second row seat and have built a system for a second console. I decided to make it one massive long console, like the Mazda RX8, but if I did that, the texture difference would be obvious. I was going to try to make the second console connect by sliding into the first, but out of wood. That would mean the soft versus hard look, something I don't like. What do you recommend?
ZOTAC GF9300-G-E
INTEL E8200
4 Gigs
OCZ Vertex 2 SSD
OPUS 320
