Results 1 to 4 of 4
Thread: Win 98 Home Network Problems
    Jul 2001
    Boise ID
    Angry Win 98 Home Network Problems
    Hi Guys :-)
    I was hoping some of you guys might be able to help me. On my home network, consisting of a linksys 4 port router/switch (connected to a cable modem), I have my computer and my roomates. Both computers are running Win 98 SE.
    A few weeks ago, my roomies comp lost all ablilty to connect to the internet, even though file/print sharing are still running strong. I checked the dhcp clients table on the router, and my roomates computer will be there one second, refresh, and then its gone. I ran winipcfg on his computer, (all the settings are quite wrong) I tried releasing, it said that it was already released, and then I tried renewing, and I got this error: "Error; Access Denied: Renewing Adapter "" " I tried searching on google, but the closest I could come was some people with the same problems, only in a win 2k/ xp area, which didn't help :-) Any ideas/suggestions would be appreciated! Thanks guys
    "We'll do this the old navy way, the first one to die, looses."
    Looking For A Second Gen 4Runner, CarPuter To Follow! :-)
    "Speaker of the Truth" veedubya's Avatar
    Nov 2001
    #1 Do you see LED activity on front of router for the corresponing port to his computer?
    #2 Move to another port on router or swap CAT5 cables. Use your CAT5 on his computer ( since yours is working )
    #3 I would double check NIC settings.
    Auto DHCP, Auto DNS etc.
    sidenote. Sounds like maybe the NIC has took a dive, would maybe explain its MAC disappearing.
    #4 Look into dumping TCP/IP and reinstalling or just reinstalling the NIC
    #5 Unplug and curse the router and computer for 5 minutes and plug back in. GUARANTEED NOT TO WORK BUT IT HELPS YOU OUT!
    Unless you changed default settings in router look for a 192.168 IP address
    Good Luck
    "Geeks dont need girlfriends we can ping ourselves"
    Sony Vaio 2Ghz 40G HHD, Routis 2004 GPS, 7" VGA TS Lilliput, BackUp Camera running RoadRunner with Simplistique Skin.
    Jun 2002
    Try swapping nic's.... see what happens...
    "If A equals success, then the formula is: A=X+Y+Z. X is work. Y is play. Z is keep your mouth shut."
    Albert Einstein
    kri is offline
    Feb 2003
    Puerto Rico
    he probably delete some file of a spyware and mess up all ur network config(it happened to a friend of mine)
    re-instal win98
