Results 1 to 7 of 7
Thread: ? about efi and timing
    May 2003
    i was directed here by a member at another forum. he said you guys would be able to help.
    currently i'm looking into the feasability of adding a turbo to a grand prix w/sfi 3.4dohc and, depending on the year, either an obdi or obdii data system. the biggest hurtle i foresee will be getting the stock computer to accept boost. what kind of setup and software would i need to control fuel injection and spark timing? how much?
    jol
    jol is offline
    FLAC jol's Avatar
    Jan 2002
    Mellansel, Sweden
    ehrm... I think that you will find info about powering a regular home pc from the generator, not much engine talk here
    Constant Bitrate monger's Avatar
    Nov 1999
    Good ole Maine. Gotta love trees and deer.
    The stock computer will not accept boost, however, there are alternative solutions.
    look here: http://www.bgsoflex.com/megasquirt.html
    Its a home built EFI computer with a native computer control, and it can be adjusted to handel a turbo/supercharger/nitros .... etc. Just remember to check your compression ratio. Turbos dont like compression ratios over 8.5. good luck
    Monger
    ICQ-7207702
    UPDATE: I moved farther north. Now its even too cold for the deer; only moose now
    May 2003
    thanks for the link. that's exactly what i'm looking for. anything out for timing?
    and don't worry about the cr. if i go through with this project, the engine will be built up for boost.
    Nov 1999
    Just read through the site that I posted earlier, they produce another product called the megaJolt. That solves your ignition problem. http://www.bgsoflex.com/mjl/mjl_edis.html
    On a side note, Just got in the Haltek controller in the mail =) mmmmm 20 lbs of boost.....
    Monger
    ICQ-7207702
    Dec 2001
    also checkMegaSpark . You'll need to build 2 megasquirts but the others don't quite have all the bugs worked out yet.
    Steve
    Mar 2001
    Cincinnati, Ohio
    www.gp-owners.com/forum
    check the 88-96 section
    Clarion 200watt head unit w/ Aux in.
    Kicker 800watt 4 channel amp
    In a 96 Grand Prix SE.
