Results 1 to 4 of 4
Thread: Convert RCA Audio To Speaker Wire
    Apr 2011
    I need help.
    I have speakers on my deck that have a wiring panel in my living room.
    I have a Satellite box that has optical audio output and RCA output.
    How can i get the audio from the satellite box and convert it to speaker wire for my speakers outside?
    I know i could connect a receiver to it, but i dont want to have all of those devices in my living room.
    I was looking into High to Low level converter, but they only seem to go one way. (Speaker to RCA)
    Any ideas?
    Sep 2009
    Reading, PA
    #1, join a different forum, this one is geared toward installing CarPC's, but you did find a good place to post!
    #2, I can answer that one though, because I love home audio. Your speakers need power. They have to be "amplified". An RCA or Optical output is not an amplified output, hence the need for a receiver. They sell High to Low because the information is there and can be stripped for RCA use, but to do the opposite you need to add power. I would research a "Class T Amplifier." They are generally very small amp/preamp units that can be used for that purpose, assuming you don't need a ton of power for those outdoor speakers. Parts Express usually has a bunch.
    Apr 2011
    Thanks for the info.
    I will check it out.
    Newbie HateWheels's Avatar
    Apr 2011
    I'm pretty much going to agree. You need an amp for your speakers. Although, I think the amp will have to be in your living room as well? You might be able to put the amp in a different area. I'm not too familiar with that set-up.
  1. Convert Speaker Wires To RCA?
    By QuickSilver2005 in forum Car Audio
    Last Post: 10-23-2006, 12:19 PM
  2. using speaker wire as power wire
    By michaelrj9 in forum Car Audio
    Last Post: 03-18-2006, 04:08 AM
  3. 1/8" Audio Out to Speaker Wire?
    By crsseyednsmilin in forum Car Audio
    Last Post: 10-24-2005, 08:15 PM
