Results 1 to 7 of 7
Thread: Attach amplifier to sub box?
    Sep 2001
    Is there any reason to not attach an amplifier to a sub enclosure?
    Jan 2003
    Ruston, LA
    vibration MAY over time, shake components loose in your amp.
    If you have expensive amps then I wouldn't risk it
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Jan 2003
    New Orleans
    I've been using several different 15's (CV, Soundstream, RF) for over 2 years now with the same CV amp attached to the box. No problems so far. But like frodobaggins said, if you're lucky enough to be running Macintosh amps, I wouldn't risk it.
    jol
    jol is offline
    FLAC jol's Avatar
    Jan 2002
    Mellansel, Sweden
    no problems here either
    Maximum Bitrate albysure's Avatar
    Dec 2000
    pittsfield, ma.
    car audio amps are designed for a car environment
    Sep 2001
    Cool then, I'm going to attach it
    Variable Bitrate vcbb5's Avatar
    Aug 2002
    Kansas
    i heard that the wood of the box can actually "flex" when ur bumpin hard and cause stress on the amp. So i think you are attach it near an edge of the wood if there is no center cross plank of wood, or in the middle if it has one. (assuming it is a 2 sub box)
    i dont know where i heard this, but i think it is good info too share. im no expert, but it makes sense.
    ex.
    http://ampbox.tripod.com/AMP.JPG
    My Mazda 3s
    My Mazda 3s on Car Domain
    [||||||||||||||||||--] (90%)
