Results 1 to 6 of 6
Thread: Voltage ONLY when engine running, NOT ON position...
    Mar 2006
    Montreal
    I've seen alot of posts regarding people who want VCC trigger only when the engine is actually running, not just in the ON/IGN position with engine off, so after finding dead ends in both cabin and engine bay fuse boxes, i snooped around and found a plug on the alternator which has 4 wire square harness (civic 8th gen). One of thgose wires actually tested 12v VCC only when the engine was actually running, it is the blue white stripped wire, so if anyone wants to find theirs, test your alternator outputs you might succeed
    Mar 2006
    Montreal
    also, never use these as direct power sources, always run them to a RELAY and use another power source (battery) for your accessory(s).
    Mar 2006
    Montreal
    White / Green is alternator control signal (ALTC) goes to ECU
    White / Red is alternator FR signal (ALTF) goes to ECU
    Black / Yellow is power to ignition goes to under dash fuse/relay box
    White / Blue is charging indicator light in dash
    Raw Wave
    Nov 2009
    Yes - you have essentially described what many use for "engine running" signals.
    For EFI systems, air flaps and injector pulses etc can be used whilst for all petrol vehicles, spark sensing can be used - noting that all of these are "active" during cranking.
    But the alternator's charge-light circuit is the choice for those wanting the "not cranking but is running" signal (for most alternators - some may extinguish the D+ or L light during cranking).
    D+/L is often used used for fuel pump relays & fuel cut & electric chokes with an added "prime" (cranking) feature.
    D+/L on its own is often used for battery isolators and certain loads (DRLs, heavy lights etc).
    Whilst DP or other ECU controlled alternator signaling can be used (with filtering etc), the simplest is the traditional charge light circuit which is traditionally low (grounded) when not charging and +12V else floating when charging.
    For those lacking that function, VSRs (voltage sensing relays) can be used (as used for other battery isolators but without the associated delays).
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    Thank you for the information but I just wanted to mention you have probed all 4 of those wires and exposed them to the elements. 1 winter or less and the copper in all 4 of the will be green and corroded and there will then shortly after be 1/4" of copper missing inside the wire casing. It may happen a little slower depending where those wires are located but still a potential problem. You may want to try to seal them back up...
    Mar 2006
    Montreal
    Already sealed
  1. Running Without Engine
    By a13n0rma1 in forum Newbie
    Last Post: 04-04-2008, 02:28 AM
  2. display position offset when running RR
    By kegbus in forum Road Runner
    Last Post: 03-26-2008, 09:55 PM
  3. Replies: 7
    Last Post: 12-19-2006, 10:29 AM
  4. Inverter and running engine?
    By (Supra) in forum Power Supplies
    Last Post: 08-28-2005, 07:50 AM
  5. End Low voltage while cranking engine
    By bluehcc in forum Power Supplies
    Last Post: 07-26-2005, 05:03 PM
