Results 1 to 8 of 8
Thread: Blown Engine Repair
    Variable Bitrate Ashlawn Kemling's Avatar
    Feb 2001
    Williamsport, PA
    Blown Engine Repair
    Now this isn't your typical car engine... it is your typical 11hp Briggs & Stratton lawn mower engine. The piston rod snapped into several pieces, one of them slamming into the crank case wall right next to the starter motor. It only cracked the metal and pushed it out a little. I pounded it back flat. The question is, if I get it welded up, insides cleaned, and the piston rod replaced, would it work?
    I know you know don't need compression in the crank case, just need to keep the oil from leaking.
    Maximum Bitrate carabuser's Avatar
    Aug 2003
    CA
    well, just one question, how the hell did you manage to break that thing?? were you racing it??
    Feb 2001
    Williamsport, PA
    Quote Originally Posted by carabuser
    Actually, I HAVE raced it in the past.... but the thing is twenty years old. That and it was trying to move a flat tire backwards up a hill.
    Jan 2003
    Ruston, LA
    Quote Originally Posted by Ashlawn Kemling
    probably, but while you are at it, go ahead and do a rebuild with new rings at least, since it's so old, it could use some new life in it
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Feb 2000
    hoppers crossing, victoria, australia
    these engines will run forever get the block welded up and it will be fine i got a friend that workjs at a gokart center and they use 9hp honda engines they crack on average a block a week and get em welded up and they keep going stronger than before
    cheers
    pcman
    donate to my team in the ****box rally all proceeds go to the cancer council http://www.everydayhero.com.au/dodgy_mechanics
    Constant Bitrate SOBIL's Avatar
    Jul 2003
    Melbourne - Australia
    while youyr at it youy should go for a bigger bore, port it out, high flow reid valve, lightend flywheel, nitrogen hardend piston, decomp plate to 12:1, and nice big garret on the side. you'll have to replace your welsh plugs coz you'll prolli end up with more pressure in your crankcase than in your cylinder. lolz =[]
    Feb 2001
    Williamsport, PA
    What did you say?
    Jul 2003
    whobwhobwhobwhob. whurrrrrrrooaaar. =======[8-8]
    Fully sick mario motors here mate.
    We up the boost on anything with a hairblower
    <SING>
    come on, come on it's not hard to learn,
    come on, come on it's called a handbrake turn.
    Oh ladies
    </SING>
