Results 1 to 9 of 9
Thread: Oil Pressure?
    Variable Bitrate Ashlawn Kemling's Avatar
    Feb 2001
    Williamsport, PA
    Oil Pressure?
    I think I might have a big problem. Just kind of learning about what exactly the oil pressure gauge means... of course my Jeep says, 20/40/80 as standard. The needle however is buried way past 80... like it would read about 120 if it was labelled. I honestly DON'T know what the oil pressure is related to, but this can't good. Might just be a bad sensor though... I have been driving it for a good 30 miles or more from the last oil change. Which I did myself.
    Jan 2001
    either a bad gauge or a bad sending unit(sensor) on the engine
    my truck does the same thing
    Constant Bitrate Suprapc's Avatar
    Apr 2003
    Scott, La
    Either bad sensor/wiring/gauge or a block in an oil passage / stuck relief valve.
    2002 Golf TDI With Phatbox . Blue 87 Supra Needs to go, Grey 89 Targa with stock Radio.
    FLAC guitar333's Avatar
    Jun 2003
    IDAHO
    What kind of jeep? I have a cherokee and i just noticed it goes all the way to the right when i have been driving for a while (freeway @ 70mph for an hour+ etc)
    92 Taurus SHO - Daily driver - Epia M10000 80GB 512mb 7" touchscreen, Opus PSU etc
    93 Black SHO - 30mpg cruiser
    90 Silver SHO - 419whp fun/project car, CarPC to come (for tuning)
    Feb 2001
    Williamsport, PA
    Quote Originally Posted by guitar333
    Jeep Cherokee 1996. It just seems to be stuck there. I'll have my dealer check it out/fix it. Thanks guys!
    Jun 2003
    IDAHO
    Is it stuck full time?
    Feb 2001
    Williamsport, PA
    Stuck all the way up full time.
    Feb 2001
    Williamsport, PA
    Apparently I had loosened the wire off the sensor when installing the oil filter. My dad fixed it for me.
    Maximum Bitrate binary.h4x's Avatar
    Jun 2003
    Fairfax, VA
    to answer you other question, the oil pressure is in relation to how much oil you have in the engine. If you have too little, the pressure will fall, but if u have too much, the pressure increases.
