Read it more closely.......
"The correct technical definition of this new type of engine is: 6-stroke isovolumetric engine with revolving con-rod and half-floating piston."
Here is how I see it and "what they call it"
Intake stroke "Intake"
Pause/intake completion, the intake velocity will force alittle more in
Compression stroke "Compression"
pause/Ignition "Constant Volume Combustion"
Power stroke "Full expansion stroke"
pause/exhaust pressure release "Free exhaust"
exhaust stroke "Forced exhaust"
pause/exhaust clear, intake begin with extended scavenging
this all still happens in 720º of crankshaft rotation, ? 4 strokes ?
it still only has 4 strokes with a pause at TDC and BDC
I don't think these pauses should be called strokes......
Mabe a 6 cycle engine
but it has realy has 8 stages.....
This looks like a good idea but it termed wrong
also this seemes like a good setup for a super charger where the top and bottom intake pauses could allow alot of air/fuel to be stuffed into the cylinder.........
lets see what others have to say before I go on
