sweet. Throw that into a hybrid automobile and you'd get such good mileage.
I still want my nuclear powered flying car though.
check this out... quite an interesting concept.
http://www.ducati.com/bikes/techcafe...neral&artID=11
~Mike
Single Member of the "1000 Post and No MP3 Car" Club
PROJECT ON INDEFINATE HOLD... BOUGHT A HOUSE
2000 Cavalier Z24 [###-------] Only 30% Done ... Still
A digital mind lost in an analog world.
Learn to ask smart questions!
http://www.catb.org/~esr/faqs/smart-questions.html
My car PC: The Lost Cause!
don't forget the "vidphone" did you ever read "safe at any speed" by Larry Niven
Originally Posted by fluffy2097
Stop Buying New Music CD's.
Hit The RIAA where it lives.
Indash Motorized 7", Epia Nehimiah, 512 MB, 80 GB, DVD, Wireless G, XP Pro, XM PCR, Kenwwod 5 Channel 1200 Watt Amp.
heh, kinda like a mix between a rotary engine and a piston engine, neat! Another nice engine trick i saw was honda's new 6 cylinder engine. When it detects a cruising speed, it will actually close all of the valves on one side, stoping the pistons from moving, all to make it more effecient. I read it in Honda Tuning, i'll see if i can find an online link.
also like honda's incline sensor, when the car is cruising down hill it turns off so when you are coasting there is no gas usage (granted the engine still spins but no fuel is consumed)
actually... comparing it to a rotary is a bit of a stretch.Originally Posted by binary.h4x
rotary engines utilize no pistons, and convert rotational energy into rotational energy. the 6-stroke engine above still uses pistons, and converts the linear motion of the pistons to rotational energy. also, if im not correct, there are no valves on a rotary engine.
as for that honda engine, i think the pistons continue moving, as they are still connected to the crankshaft. the valves most likely remain closed, and the fuel injection is probably cut off to those cylinders as well...
~mike
Yeah, stopping the pistons would be bad, very bad !Originally Posted by mp3z24
[H]4 Life
I'm a lesbian too.
I am for hire!
sorry, i meant stop producing power, and the rotary coment, the central spinnin thing just reminded me of a rotary engine diagram![]()
No moving "conventional" valves like on a piston engine, but they still have valves/ports. And newer rotarys have ports that will open/close depending on the needs of the engine, but they dont actually open per stroke.Originally Posted by mp3z24
Edit: And I dont know much about vtec, but that sounds like what binary is describing, the cam lobes lock/unlock from the camshaft to open/leave closed additional valves. So maybe the pistons lock/unlock from the drive shaft, i dont know.
-Nick
_____________________________
Monthly MP3Car Chicago Meets
www.mp3vw.com Last updated: 07/07/2008
VTEC engages a second longer duration camshaft. <- from my understanding. Cadillac shuts down cylinder on its North star engines by no longer actuating the valves. Don't know about Honda.
2002 Golf TDI With Phatbox . Blue 87 Supra Needs to go, Grey 89 Targa with stock Radio.
