Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
Thread: Electronics Gurus - Read Here
  1. #21
    Raw Wave
    Jun 2003
    Might as well point a movement activated shotgun
  2. #22
    FLAC Gutter's Avatar
    Dec 1999
    Italy
    Quote Originally Posted by Altimat
    Screw the camera. Have the light activate an alarm in your room and head out with the baseball bat when it goes off.
    I thought about that, but would you be willing to run out there every single time a cat jumps on your car or a leaf falls from the roof? Having to park my cars outside, I'm never going to be safe from thievery, but I can at least keep a record of what happens out there.
  3. #23
    Newbie AVmobile's Avatar
    Dec 2003
    Los Angeles
    Found This on ebay this should do the trick...
    Heres a DVR card on EBAY...
    http://cgi.ebay.com/ws/eBayISAPI.dll...category=48634
    Hope that helps.....
  4. #24
    FLAC Pudge's Avatar
    Sep 2003
    AZ
    If you've got an input... Why not record with software? Maybe these links will help, and maybe it's not what you're looking for
    http://download.com.com/3000-2348-10...ml?tag=lst-0-1
    or
    http://download.com.com/3000-2194-10...ml?tag=lst-0-2
    or if you have a webcam
    http://download.com.com/3000-2092-10...ml?tag=lst-0-1
    I Know it's not linux, but might be easier.
    My Carputer! (More Car Pics at the end)
    2 Kicker Comp 10"
    Epia M-9000, 256 MB DDR, 120 Gig HD
    Lilliput 7" VGA Touchscreen
    Check it out?!
  5. #25
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Why NOT go with the X10 motion activate camera and VCR commander?
    Yes, I don't really like X10 (because of their stupid pop-up, down, under ... ) stuff and using VCR but hey it work the way you want right?
    Since X10 VCR send an IR Record command to your VCR, you can use that IR signal to your computer and record whatever you want. I think the X10 VCR Commander only has 3 buttons/4functions Power ON-OFF, Record, Stop.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  6. #26
    Nov 2003
    actually ATI capture software has something like this already in it, you can exclude the area around your car, and when someone goes near the car it will start recording, when no activity is recorded it goes back to stand-by mode
  7. #27
    Maximum Bitrate GingerPrince's Avatar
    Apr 2003
    Leeds, UK
    Quote Originally Posted by Hcomplyr
    So does the stuff that comes with Logitech cameras. It monitors the image it gets for changes, and when there's a more than 5% change in the picture or something, it starts to stream to disk.
    GingerPrince
    Car changed for TVR Griffith 500, so computer de-installed. Using a Dension 100ix w/60Gb HD unit in the interim.
    Carputer Install - http://www.stuffandting.com/carputer/
    CarBox Software -- http://www.stuffandting.com/carbox/
  8. #28
    Dec 1999
    Italy
    Here's the deal. I have a 110VAC line coming from a motion detector outside. When motion is detected, the line goes hot. Inside the house, it simply needs to close a two ports on LPT1 with no voltage. A relay would be the answer. I have a pile of these:
    http://www.oceancontrols.com.au/rela...y%20RW-RWH.pdf
    Any way I could utilize them, or should I just wait and grab an AC relay in the morning?
  1. Reading one thread marks all threads/forums read
    By Micahb in forum Mp3car Forum Suggestions/Comments
    Last Post: 11-11-2002, 04:56 AM
  2. Calling Electronics gurus!
    By phil.45 in forum General Hardware Discussion
    Last Post: 10-04-2002, 07:19 AM
  3. Attension Electronics Gurus
    By Rob in forum General MP3Car Discussion
    Last Post: 09-20-2002, 06:10 AM
  4. Do you work in te field of electronics???
    By THEMP3KID in forum Off Topic
    Last Post: 02-12-2002, 10:02 AM
  5. Another inverter question...for electronics gurus
    By moahdib in forum Power Supplies
    Last Post: 06-07-2001, 09:30 PM
