Results 1 to 8 of 8
Thread: help drive death
    FLAC chut's Avatar
    Jul 2003
    San Antonio, TX. USA
    can you find an exact duplicate of that drive and switch the platters? I know it sounds goofy butmy wife and I once pulled it off. If it's your drive controller that's bad.
    Stop Buying New Music CD's.
    Hit The RIAA where it lives.
    Indash Motorized 7", Epia Nehimiah, 512 MB, 80 GB, DVD, Wireless G, XP Pro, XM PCR, Kenwwod 5 Channel 1200 Watt Amp.
    Aug 2002
    longview washington
    that would be easy
    its a partition crash from a messed up partitionmagic job i was doing
    WINNER!!!!
    run-on sentance comp 2002!!
    FLAC Gutter's Avatar
    Dec 1999
    Italy
    If the partition is inaccessible, I have serious doubt you'll recover anything. The only time I've ever gotten successful or partially successful recovery is while the partition is still readable.
    Aug 2002
    longview washington
    oh i can get files back but with a stupid hareware proggie
    that only recovers 64 kb of the file
    unless i give them 40 bux
    dam greedy peopl
    anyone got any proggie suggestions?
    WINNER!!!!
    Variable Bitrate Banderon's Avatar
    Sep 2003
    NJ
    I used "Lost & Found" back in the day, but that's been discontinued. It required another HD to restore the data to. I got it when I accidentaly erased an entire partition in fdisk.
    Search around, you might find it.
    Constant Bitrate parawing742's Avatar
    Jun 2003
    Tennessee
    I have a program that I've used effectively to restore data on a drive with all the partisitions deleted. I can e-mail it to you, but it's about 3 megs in size. Let me know...
    Phillip Hullquist
    I entertain people through adventure movies.
    www.11visions.com
    Maximum Bitrate deadweasel's Avatar
    Nov 2003
    Detroit MI
    Hands down, Best. Program. Ever.
    OnTrack EasyRecovery. It's expensive as all heck, but there are "trial" versions out there.
    When my 80gb WD drive crashed, it couldn't see anything, but after I repartitioned the drive and formatted it in frustration, I tried once more, under "Format recovery" option, and everything, and I mean EVERYTHING was recovered in a 10 hour period. It does take some time to work, but it WILL save your data. If all you have is a gimped partition, grab that software and try it out. If it still won't dig anything up, repartition the drive correctly, and try recovering again. This program is the bomb, and is the first thing OnTrack would try in their labs (and charge you $700 for it).
    My drive's controller was failing outright, and Windows almost refused to even boot when it was connected as a slave to the system, but that software STILL recovered everything! Can't recommend them highly enough. Whenever I get the money to toss at them, I will be buying a legal copy. I snagged that "demo" version *wink wink* because I wasn't about to throw a few hundred dollars at them to see if it worked in the first place. Now that I know how badass it is, I will be buying the full version for emergencies later. Well worth it IMO.
    The ALEXIS Project
    MP3---VIDEO---GPS---REARVIEW---OBD---SKINNING
    Color Coding :
    DONE / MOSTLY DONE / BASE FEATURES / WORKING CONCEPT / NO CODE COMPLETED
  1. Hard drive upgrade problems :-(
    By Arex in forum General Hardware Discussion
    Last Post: 04-29-2006, 01:53 PM
  2. Hard drive shock problems.
    By Mikesz in forum General Hardware Discussion
    Last Post: 03-21-2005, 04:37 PM
  3. Killed my on-board 250G shock laptop drive
    By spectrumzz in forum General Hardware Discussion
    Last Post: 04-07-2004, 01:34 AM
  4. All-electronic flash drive and solid state hard drive
    By Typhoon747 in forum General Hardware Discussion
    Last Post: 12-12-2003, 03:20 PM
  5. External notebook hard drive help
    By mtmsol in forum General Hardware Discussion
    Last Post: 04-18-2002, 01:24 PM
