Results 1 to 10 of 14
Thread: Cutting holes in sheet metal and other dangerous tales
    FLAC Gutter's Avatar
    Dec 1999
    Italy
    I'm trying to mount some VGA, sound, and USB headers onto a single piece of sheet metal. Any thoughts on the best way to cut out those holes? The sound holes can be done simply with a drill, but the VGA and game port holes are going to be a *****.
    I would like this to be pretty clean, so let me hear your ideas on the best way to approach this.
    Maximum Bitrate brrman's Avatar
    Aug 2003
    Indianapolis, IN USA
    You need a Dremel with a fine cut tungsten bit. That would do the trick
    Car: 2000 Audi A4 Avant 1.8t
    Carputer 2.0: removed. Back to stock.
    Constant Bitrate StationRocket's Avatar
    Sep 2003
    Rochester, NY
    you can get special punches that make exactly the right hole. i think there is a company called Greenlee or Greenleaf or something like that that makes them. They will be much cleaner than if you do it with a dremel but the punches will probably be $20 or more each.
    FLAC LESLIEx317537's Avatar
    Jan 2002
    Long Island, NY
    You can also try a PC backing template and cut a rectangle into the sheetmetal for the template and place the template into the rectangle.
    Many motherboards come with a custom backing template to accomidate special ports.
    SP13000|M2-ATX|512MB DDR400|2.5" 7200RPM S-ATA|Trans-7"|Slim SL DVD-CDRW|KEH 5.1 DSP|SB L!ve Ext|Gyration PowerMate|BT|WiFi|GPS|WinXP|VoomPC
    GPSing - Digital Speedo
    Relocating headunit and extending faceplate
    Button app to Alt-Tab between two programs
    Dec 1999
    Italy
    brrman - That's most likely how I'll do it. I still have the original metal brackets that they were connected to so I can just use them as templates.
    StationRocket - That's a good idea about the punch, Station, but waaay too expensive. http://www.mouser.com/catalog/618/1258.pdf Maybe there are cheap alternatives out there.
    LESLIEx317537 - If I could cut a clean rectangle, then I could just cut a clean hole for the VGA and game ports.
    Raw Wave god_of_cpu's Avatar
    Jan 2004
    SilverSpring Maryland
    I used a drill to start all the holes, tin snips for the larger areas, then a dremel as brrrman suggested for the edges for my aluminum faceplate.
    To do the square hole for the USB port, I just drilled a starter hole, then taped the old steel mounting bracket for the USB port in the proper place to the aluminum face plate without the wire in it and dremeled the hole out until the edges were perfectly even.
    StreetDeck.com Developer (I am Chuck)
    Get StreetDeck at http://www.streetdeck.com
    The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
    Dec 1999
    Italy
    Wow, nice work on the hard drive mount. That's the most elaborate one I've seen yet.
    Mar 2004
    Maryland
    Dec 1999
    Italy
    Holy crap. Have you used it before? Do you know how well it works?
    Sep 2003
    Rochester, NY
    i have one of those
    it's called a nibbler. it's what i used to make the holes in my case for the power entry and the other stuff that wasn't included in the plate that came with my epia motherboard.
    Just like using a dremel it will do alright if you work slow and have good hands.
    i'd try out your skills on a spare first
