Umm...well, there really isnt a *good* solution, because to use it you will need to leave your car in neutral with the e brake on to hold it. It is easy to bypass the clutch pedal switch but the one time you attempt to start it in gear it could get uglyOriginally Posted by lgbr
probaby wouldnt be too bad to come up with a switch to make sure its in neutral, but you still cant get past the e brake thing. I dont know about you but I dont trust just the e brake
LinkBack URL
About LinkBacks
) in the process.
